Thetis 2.10.3.5 Final Now Available
Trucker
Re: Thetis 2.10.2 Final Now Available
Post by Trucker »
Old age strikes again!
I had the wrong version installed. Downloaded v2.10.2.1 and installed perfectly. The cpu usage matches what is shown in Task Manager. And the display has the option to switch between System and Thetis cpu usage. I can select either one and it will match what is shown in Task Manager. Very nice. I am glad that Thetis is separate from the radio as there is less for me to mess up!
vk1hx
Post by vk1hx »
Trucker wrote:Old age strikes again!
Version 2.10.2.1?
73, Phil - VK1HX
Trucker
Post by Trucker »
Version 2.10.2.1?
https://github.com/ramdor/Thetis/releases/tag/v2.10.2.1
ea3aqr
Post by ea3aqr »
Version 2.10.2.1?
Yes, it solves an issue i've detected with quick split function failing when VFO sync was activated.
vk1hx
Post by vk1hx »
Thanks James,
Gee that update came out quick. I only saw 2.10.2 official release. :)
73, Phil - VK1HX
vk1hx
Post by vk1hx »
Unfortunately, I can't download 2.10.2.1.
Windows defender has detected Thetis 2.10.2.1 as a virus.
Screenshot 2023-10-13 093637.png (17.15 KiB) Viewed 42437 times
73, Phil - VK1HX
vk1hx
Post by vk1hx »
Getting the virus detection on another PC running Windows 10. The main PC is running Windows 11 PRO also getting the virus detection.
73, Phil - VK1HX
Trucker
Post by Trucker »
That's odd. I am running Windows 11Pro and keep it updated. I didn't get any warning from Windows Defender other then the initial thing about it being an exe file and did I really want to run it. I clicked ok and during installation I got the Blue Pop-up box telling me that Defender was blocking the installation till I clicked on run install anyway.
I do a virus scan afterwards and no hits. Windows 11 is much more protective than in the past.
While a bit annoying, it is better than letting anything get installed.
vk1hx
Post by vk1hx »
Trucker wrote:That's odd. I am running Windows 11Pro and keep it updated. I didn't get any warning from Windows Defender other then the initial thing about it being an exe file and did I really want to run it. I clicked ok and during installation I got the Blue Pop-up box telling me that Defender was blocking the installation till I clicked on run install anyway.
Yeah I get that same message for all other installs. Everything is up to date.
I downloaded the source code file and scanned it for a virus, nothing found. Very odd. I know people will say false positive etc etc, however I wont by-pass the detection. How do I compile the source code into my own exe/msi install file? Maybe I can do it that way and give 2.10.2.1 a try.
I don't get a virus detection on 2.10.2. very odd.
73, Phil - VK1HX
I have removed it from the release, completed a full virus check on my system, nothing. Ran virus total on the msi, nothing. Re-uploaded. Perhaps a glitch in the matrix. Either uploading or downloading caused some sort error that resulted in a false positive. Very odd.
virus total scan on the msi
https://www.virustotal.com/gui/file/cee ... fe32c50ec/
The trouble is, these days you get some odd byte order in a legit file and boom, it becomes flagged as a virus, a false positive. Price we have to pay I guess for non-signed installer.
vk1hx
Post by vk1hx »
ramdor wrote:I have removed it from the release, completed a full virus check on my system, nothing. Ran virus total on the msi, nothing. Re-uploaded. Perhaps a glitch in the matrix. Either uploading or downloading caused some sort error that resulted in a false positive. Very odd.
Very good, yeah I can't explain it either. I'll try the download again. Cheers.
73, Phil - VK1HX
vk1hx
Post by vk1hx »
Just redownloaded the update. Clear of Widows Defender virus detection.
All good, thanks for updating. Now to test.
73, Phil - VK1HX
vk1hx
Post by vk1hx »
Installed version 2.10.2.1 and both System CPU and Thetis CPU readings are at 3% sometimes 5%. So looking normal. :)
73, Phil - VK1HX
UPDATE v2.10.2.2
Another update sorry. There was an issue importing exported TX profiles that had been introduced with changes to some version checking code. This should now be fixed in v2.10.2.2
https://github.com/ramdor/Thetis/releases/tag/v2.10.2.2
Trucker
Post by Trucker »
Ritchie, thanks for the update. This was an issue I had with the previous update. I had to redo all my Transmit settings to get everything right. ( probably should do that occasionally anyway)
Thank you Richie. Is it okay to just install this over a previous v2.10.2 build?
W2PA
Post by W2PA »
ramdor wrote: Another update sorry.
No need to apologize when you give a gift to the assembled multitude. :) Thanks!
Chris, W2PA
iu4jnr
Post by iu4jnr »
thanks Richie for the updates.
Just to report a behaviour when opening CWX. Thetis get frozen and then stucks my PC. IT's just to me?
gaming PC win11 Ryzen7 5800X, 128 GB RAM, M2 SSD RTX3060
Max IU4JNR
DK1WP
Post by DK1WP »
iu4jnr wrote:Hi all,
Max IU4JNR
CWX is without any problems.
Windows 11, MSI B550, Ryzen 7 5800x, SSD Samsung 980, 32 GB Ram, GeForce RTX 3060TI.
Marcus
Max IU4JNR
Make sure DisablePTT is unchecked in Setup>General>Options>Options1
Could be that the msgbox is not on top warning that PTT is not enabled.
iu4jnr
Post by iu4jnr »
thanks for reply.
I checked PTT and it was unchecked. I checked it, turned Thetis Off, unchecked again and then CWX started to work.
Thank you very much.
Max IU4JNR
Post by W1AEX »
Thanks Richie! Version 2.10.2.2 has been running all day here on several different bands without any issues. I think my coffee even tastes better with this release!
ginger
Post by ginger »
installed 2.10.2.2 this morning and everything is fine apart from when scrolling with the mouse wheel to get on frequency the tune step will only move in 2hz steps even thoe i have selected 1hz steps ....... anyone else having this issue
Tony M0VDO ANAN 8000DLE
UPDATE !!!!!! problem solved , In the navigation tab I had to option ticked to use specific mouse wheel , plus the box ticked to listen for wheel when no app focus is present , I no longer use a separate vfo so after un checking these options the problem was gone.
ginger wrote:installed 2.10.2.2 this morning and everything is fine apart from when scrolling with the mouse wheel to get on frequency the tune step will only move in 2hz steps even thoe i have selected 1hz steps ....... anyone else having this issue
fine here Tony. If you set it to 2 does it move by 4, so like double of what you have selected?
ginger
Post by ginger »
nice one :)
yes, probably getting two wheel events if you were using that special specific mouse thing as well
vk1hx
Post by vk1hx »
No need. Sorted
73, Phil - VK1HX
Not nearly enough info there to understand your mate's problem. Have your mate join up here and start a new topic with more details.
Alexander UC
Post by Alexander UC »
Does not broadcast vac2 quadrature. The output is overflowing. Protocol2. Now you need to always turn on receiver 2.
In older versions, this does not need to be done; the quadrature was broadcast on the frequency of receiver 2, regardless of whether it was turned on or not. This was convenient, for example, for using a skimmer when the screen of the second receiver is completely unnecessary.
It looks like the quadrature is not being broadcast from the transceiver. This is done in the firmware for protocol2.
The multimeter display settings behave strangely - attack and decay. Minimum and maximum operate in reverse.
w8du
Post by w8du »
I just got a new computer running W11 Pro. What is the best way to move all the settings and memories in Thetis v2.10.1 from my old computer to Thetis v2.10.2 on my new one?
Tnx de Arnie W8DU
Locked
