I wanted to enable SSH and VNC, and I changed the password. Also, I updated the OS. I guess this broke p2app since Thetis no longer sees the SDR. I'm okay with following directions, but not sure what to troubleshoot. I tried a few things I read here, but still get this error from Thetis. I'll keep searching around, mean while, no radio since I want to use Thetis. I see there is an image I can download and may try that on a new card. I would like to just fix p2app though without opening up the radio.
I tried starting p2app and get this.
Any ideas?
G2 no display...I broke P2APP
Re: G2 no display...I broke P2APP
Still reading the manual and hoping I can get it working.
administrator
See this link: viewtopic.php?f=48&t=4778&fbclid=IwAR0K ... Y64ldYgemg
Since the XDMA driver is kernel dependent you will need to rebuild it.
Regards,
Tony
Regards,
Tony
Thank you very much Tony. That did in fact resolve my issue. I did not realize that updating Raspbian would cause this. Following this and a reboot seems to have fixed my radio.administrator wrote:Hi,
Regards,
Tony
The issue here is: the operating system kernel has been updated, and the device driver now needs to be recompiled to match. The good news is it only needs a recompile, not patching. This seems to be unavoidable with linux unless someone can tell me how to avoid it otherwise!
open a command window and type:
cd ~/github/Saturn/linuxdriver/xdma
make
sudo make install
sudo modprobe xdma
if there are no error messages, it is now fixed. You can check by using your file browser to visit the /dev folder. It should now include /dev/xdma and some similar names that weren't there before.
