Thetis v2.10.3.5 final release
Re: Thetis v2.10.3.5 Pre-Release
Installed pre-release 5. So far after running for several hours, it has been rock stable. No overflows and underflows of any kind. I have to look close just to be sure the numbers are changing! Everything I have tried has worked smoothly.
Thanks Ritchie Thetis just gets better and better.
Installed pre release 5 and noticed that if you hold the mouse over CM indicator logo the pop up info message flashes on/off. Anyone else seeing this ? CAT TCP enabled message next to it works ok.
Hi Tony,
Not seeing the blinking cmASIO icon, looks steady here on pre-5.
My CAT/TCI icon is OFF however.
Bryan
Bryan
this happens with some/all status bar tool tip text afaik, some external program perhaps interacting with it, or some other reason. Not looked into it but I am aware. The toot tip text is only set once at startup for the cmASIO icon, and not/shown hidden by any code, so it hiding/showing is some failing of windows/statusbar/the universe/simulationTony EI7BMB wrote:Installed pre release 5 and noticed that if you hold the mouse over CM indicator logo the pop up info message flashes on/off. Anyone else seeing this ? CAT TCP enabled message next to it works ok.
seems to be caused by mouse pointer entering the tool tip, causing mouse leave event on the icon, closing the tooltip, and then it cycles. Just have to live with it for now as I don't really have plans to re-write Microsoft's tool tip system
This can also be seen if you move/expand the console window so the status bar is very close/slightly behind the desktop TaskBar.
Just turn off CAT/TCI and it works FB
if onlyW4WMT wrote:Just turn off CAT/TCI and it works FB
Can't duplicate your bug.
Works fine here OM
Works fine here OM
not my bugW4WMT wrote:Can't duplicate your bug.
Works fine here OM
It happened to me once since installing pre-release 5. Flashing occurs when hovering the mouse over TCI, CAT/TCP, or CM. Restarting Thetis stopped the flashing.Tony EI7BMB wrote:Installed pre release 5 and noticed that if you hold the mouse over CM indicator logo the pop up info message flashes on/off. Anyone else seeing this ? CAT TCP enabled message next to it works ok.
Haven't seen it occur since.
I also have the flashing. Began on prerelease 4 when there was only the cmASIO icon on the left. Now all 3 icons work solid the first time and then flash after that.
W9EZ
W9EZ
Todd
GeForce GTX1080
GeForce GTX1080
Thanks guys. As Richie says no big deal right now.
they flash/cycle all the way back to v2.6.9 which was the first version that had the status bar, back in Jan 2020W9EZ wrote:I also have the flashing. Began on prerelease 4 when there was only the cmASIO icon on the left. Now all 3 icons work solid the first time and then flash after that.
W9EZ
It's in Thetis since 2.6.9 and it's a microsoft bug. Case closed.W9EZ wrote:I also have the flashing. Began on prerelease 4 when there was only the cmASIO icon on the left. Now all 3 icons work solid the first time and then flash after that.
W9EZ
https://www.oe3ide.com
I feel jealous because I can't make it flash here
Wanna swap ?
W4WMT wrote:I feel jealous because I can't make it flash here
Awesome.. THanks for the replies guys.. Not much of an issue I guess since I really hadn't noticed or tried to use them until the cmASio icon came about.
Todd
GeForce GTX1080
GeForce GTX1080
73, Phil - VK1HX
Thanks Phil
Re: Thetis v2.10.3.5 final release
Thetis v2.10.3.5 final release is out over on github here : https://github.com/ramdor/Thetis/releases
Cheers for all the testing during the pre-release stages. Have a good Christmas folks. Cheers.
Overview video : https://youtu.be/aTvEznU2fY8?si=I9vJ1bnUVAPN0lEO
Thanks so much Richie,
I looked over all of your cleanup of so much of the massive lines of code! All I can say is you must be super fast at working lines of code. I couldn’t believe all of the work you did and with all of the great additions. Thanks again to all for the great updates and additions.
73’s
73’s
Thanks Richie, Happy XMas
First of all, thanks for the final release.ramdor wrote:Thetis v2.10.3.5 final release is out over on github here : https://github.com/ramdor/Thetis/releases
But unfortunately I have a problem with the 6m band.
After installing the final release, RX on 6m band is about 20db lower.
Going back to pre-release 5 cured the problem.
I am seeing the same here on 6m
ea3aqr wrote:ramdor wrote:Thetis v2.10.3.5 final release is out over on github here : https://github.com/ramdor/Thetis/releases
After installing the final release RX on 6m band is about 20db lower.
Thank you Richie for all your hard work
Happy Xmas and new year to you and your family
and to all on the forum
73s
liam
73s
liam
UPDATE: fix to 6m lna. Same version number but titlebar will show 'u1'. Please test.Tony EI7BMB wrote:I am seeing the same here on 6m
The spaceship would now be heading the wrong direction as a damn pesky ! was removed in the code clean.
U1 looks good here Richie , even have an E's opening on 6 to test with
ramdor wrote:UPDATE: fix to 6m lna. Same version number but titlebar will show 'u1'. Please test.Tony EI7BMB wrote:I am seeing the same here on 6m
Thanks for the quick test. Yeah there were thousands of lines of code junked in the project. I should have probably run a pre-release-6Tony EI7BMB wrote:U1 looks good here Richie , even have an E's opening on 6 to test with
no worries, thanks again for all the work
73, Phil - VK1HX
