indepenten VAC1 using RX1AF ???
OZ1CT-Ben
Postby OZ1CT-Ben » Sat Jan 06, 2024 12:52 pm
I am using cmASIO and when I run digital (using VAC cable to MSHV software) and you turn down the RX1af you also turn down the VAC1 af level :-( is there a way to have a indepenten VAC 1 ????
Ben
Re: indepenten VAC1 using RX1AF ???
Postby w-u-2-o » Sat Jan 06, 2024 1:42 pm
Sort of. Master AF will control the overall audio level for cmASIO. My recommendation would be to set RX1 and RX1 AF to maximum. This will achieve a proper and optimal 0dB audio level into digi mode software attached via VAC. Then use Master AF to adjust cmASIO audio level and which does not affect VAC levels (however, beware a variety of options in Setup > Audio > Options than can change this behavior).
Postby oe3ide » Sat Jan 06, 2024 2:10 pm
Or you can just use the mute function. Be sure that "Mute will mute VAC" in VAC1-tab is unticked.
OZ1CT-Ben
Postby OZ1CT-Ben » Sat Jan 06, 2024 2:39 pm
I did as Scott is writing...
full speed on RX1 AF and adjust the Master AF
and the adjust the level in MSHV software for correct AF level :-)
but it wuld be nice if you have a VAC1+2 there is not indepenten of the RX1+2 AF settings, as you always can set the RX-gain for correct level.
tnx fer help !
Ben
