Updated G2 firmware and p2app June 2024
laurencebarker
Post by laurencebarker »
I've pushed version 17 of G2 firmware and v25 p2app to the GIT repository.
The firmware changes are mostly around improved TX composite noise performance, and variable ramp rate CW (to allow minimisation of the spectrum occupied).
piHPSDR users will need to pull an update of the code and rebuild; see the G2 manual for details.
There is also a "beta" function in p2app to allow Thetis users to use the front panel controls on the G2. We don't know if this coexists with other "CAT over TCPIP" applications, or how stable it is. To test this code you will need to run p2app with a -p command switch:
p2app -p
(You can do that from inside a command window, or edit the settings for the p2app desktop icon; see the manual for more details)
Enable CAT over TCP/IP in thetis, and p2app will send CAT commands from the front panel encoders and pushbuttons to thetis. You will need to use the Andromeda setup page in Thetis setup->network/serial/midi CAT to edit the settings for what each control does - see the thetis manual for details.
Finally to see the assigned function for a "multifunction" encoder, the Andromeda CAT port needs to be enabled. As a workaround, select COM1 on the Andromeda table and click panel enabled.
DL8LAQ
Re: Updated G2 firmware and p2app June 2024
Post by DL8LAQ »
Hi Laurence,
all updates performed. I still have to figure out how to use the front buttons with Thetis :-)
W7GES
Post by W7GES »
Laurence,
I have updated my G2 and started "playing around" with the front panel controls.
I haven't tried every control yet but I'm happy to say the majority of the ones I've tried such as the tuning encoder / volume / drive / MOX etc work well.
I'm sure there will be some tweaks necessary to get all the buttons working but it looks great so far.
I am able to switch back and forth between the front panel VFO encoder and the ELAD TM-2 external encoder so there aren't any glaring incompatibilities with an additional CAT over IP device that I've seen so far.
I haven't tried a contact yet, so no comments on TX composite noise / CW variable ramp rate haha.
Thanks for all your hard work!
George / W7GES
K5WC
Post by K5WC »
In the Serial/network/midi cat tab I tick server running box and it displays CAT TCP on the bottom bar by the CAT indicator that I’m using for my amp coms to Thetis. I have the box ticked for Andromeda enable panel on com 1.
But no joy on the front panels changing anything yet.
Where is this Enable CAT over TCP/Ip at in Thetis? I’ve updated and am running the beta -p screen version.
W7GES
Post by W7GES »
Here are the settings windows from Thetis. As you can see I chose COM1 for the Andromeda tab and did not enable it on the CAT tab.
I haven't tested every panel button but AF volume / Drive / Tuning / MOX / 2 Tone / VFO work FB.
I will need to play around to see how to get the encoder push PS on off to work when I have a little time.
George / W7GES
Screenshot 2024-06-24 140016.png (27.71 KiB) Viewed 15196 times
Screenshot 2024-06-24 135942.png (49.23 KiB) Viewed 15196 times
Screenshot 2024-06-24 140110.png (31.61 KiB) Viewed 15196 times
K5WC
Post by K5WC »
Thanks again George for the information. I set mine as yours is but still no joy. I’ve now connected straight to the PC LAN with no difference.
73 Jon
W7GES
Post by W7GES »
K5WC wrote:Thanks again George for the information. I set mine as yours is but still no joy. I’ve now connected straight to the PC LAN with no difference.
73 Jon
Make sure the BIND IP port in the network set up tab is set to either local host or the IP address of the computer running Thetis, not the IP of the G2.
K5WC
Post by K5WC »
73 Jon
Thanks again George, I’ve tried it with both options in the IPV4 127 localhost and the 192 oh course that one will change if I’m plugged straight from the PC to the G2 but neither work. I am assuming that while it keeps (0 clients ) and there is no activity in the show log it’s not establishing proper connections. Disabling firewall didn’t make any differences. Unfortunately I’m beyond my scope of expertise. Thanks 73 John
K5WC
Post by K5WC »
Finally had a bit of time today, did a git pull and make. Started the P2APP -p and the TCP/IP CAT shows (1 client) and the buttons and knobs are live now. No clue what or why they didn’t work previously. Thanks for the screen shots and help George.
73 John
W7GES
Post by W7GES »
Just happy to hear the G2 knobs are working for you now.
I still haven't tried it out much as I have a long list of items on my to do list.
George / W7GES
g6phf
Post by g6phf »
This may be a daft question, I just got a G2 last week. How do I see the current firmware version I am running?
Is this the correct place? If so mine shows 2.0.0 which seems very different to version 17 mentioned here?
Screenshot 2024-10-30 at 10.13.19.jpg (23.74 KiB) Viewed 12821 times
DL8LAQ
Post by DL8LAQ »
g6phf wrote:Hi,
Hi Mike,
just start the p2app and you will see all the information on screen.
[img]
[/img]
PH7R
Post by PH7R »
DL8LAQ wrote:
g6phf wrote:Hi,
Hi Mike,
[img]vncviewer_2024-10-31_10-28-46.png[/img]
Received my Anan G2 yesterday with the following:
Raspi OS Buster 10 is installed (Raspi model 4). FPGA bit file 30092023. Saturn product version 2. FPGA FW 10.
So this means I need to upgrade to FW 17. Task for the weekend to read the manual and how to upgrade to FW 17.
Can I find somewhere difference between 10 and 17?
DL8LAQ
Post by DL8LAQ »
PH7R wrote:
DL8LAQ wrote: Received my Anan G2 yesterday with the following:
You can use "git log" to see the version history.
PH7R
Post by PH7R »
Thks found it and downloaded V17. Also downloaded instructions from N4VFR.
Question: do I need to update Rasp OS (Buster 10) to install all (security) updates with sudo apt update / sudo apt full-upgrade?
DL8LAQ
Post by DL8LAQ »
Don't do an update of RaspberryPi OS!!! You will most likely loose the xdma driver for the Orion board and the display driver. Don't ask me why I know that :-) Some guys did that and could fix the problem, but I didn't note the description how to do that.
Where can I find the instructions from N4VFR?
PH7R
Post by PH7R »
DL8LAQ wrote:
PH7R wrote:
DL8LAQ wrote:Where can I find the instructions from N4VFR?
https://www.youtube.com/watch?v=naFHlwT ... arrenN4VFR
And file attached
Anan G2 Firmware Update instructions.docx
(6.11 KiB) Downloaded 303 times
DL8LAQ
Post by DL8LAQ »
PH7R wrote:
DL8LAQ wrote:
And file attached
I watched the video. But why is he downloading the FPGA bin-file from github? That's nonsense, because the new bin-file is already there after make. that is also clearly seen in the video :-)
Checkout Laurence Barker's update guide: viewtopic.php?f=48&t=4772
g6phf
Post by g6phf »
DL8LAQ wrote:
g6phf wrote:Hi,
Hi Mike,
Thanks, so it looks like I have FW version 10?
Seems odd to be shipped from factory with an old version? Or am I missing something?
Screenshot 2024-11-01 at 16.20.43.jpg (117.56 KiB) Viewed 12654 times
PH7R
Post by PH7R »
Yes, I received my Anan G2 Wednesday with the same FW 10. I would also have expected to have the latest FW installed or at least the previous one. But it is what it is and not difficult.
EA2K
Post by EA2K »
I received my Anan G2 Ultra around 2 months ago, and the same old version. Moreover in my case the front knobs didn't work with the last Thetis version. I did the upgrade to the last version and the front knobs began to work.
Here I explained my case:
viewtopic.php?f=48&t=5176
73 Jose
EA2K
