Thetis Development Build 2.10.3.6 dev_7 available
Re: Thetis Development Build 2.10.3.6 dev_7 available
Updated to dev_8(wip12)
Another test build, you will see dev_8(wip12) in the title bar.
Dropbox link : https://www.dropbox.com/scl/fi/to9qq6zc ... qz7z3&dl=0
Note: if you have been using the rotator meter item, it will need to be removed/re-added. There are options to view as Az/Ele/Both.
- Web Image meter item as been added. It is primarily designed to point towards image links.
- New minimise option for meter containers which will cause them to be minimised along side the main thetis window if enabled (default)
Cheers.
Yevgeni
Post by Yevgeni »
Is it possible ?
W2PA
Post by W2PA »
By the way, the new Web Image "meter" element works with local files, too. Check out my Thetis console with a classic Drake R-4B VFO. (Well, of *course* it doesn't really tune - what were you thinking? :D )
Chris, W2PA
yes file:// will do it ;)
EA2K
Post by EA2K »
Hi!
I'm using the multimeter with the LP100A Bridge, and it is running very well.
As now it is possible to read the power of the amplifiers on the multimeter, could the upper limit of the power scale be changed i.e. to 4.000?, now the limit is 2500.
Useful for testing some amps ;)
73 Jose
2024-08-03 114915.png (35.58 KiB) Viewed 6869 times
yes, limit will be 5kw now
NC3Z
Post by NC3Z »
@Richie Just a little typo this should be .org not .com
Screenshot 2024-08-03 070449.jpg (14.62 KiB) Viewed 6842 times
thanks Gary, resolved. Some really nice datasets from Fred over on bsdworld. I especially like the propagation heat maps.
dev_8 released
please visit the thread : viewtopic.php?f=9&t=5140
Locking this thread now that we are moving on to dev_8. Follow the link Richie has provided above to the dev_8 thread, please.
Locked
