WINKEYER FSK RTTY
KC4LZN
WINKEYER FSK RTTY
Post by KC4LZN »
Reviewing this thread, viewtopic.php?t=3801, I tried to work this using what little information was provided in efforts to test even the CW portion of using a WinKeyer with the ANAN 7000 DLE MKII but have failed miserably.
I have been successful in setting up and using the 7000 DLE MKII with N1MM, MMTTY and work with AFSK RTTY. As most of you may know, the WinKeyer will transmit FSK RTTY. I have not been able to succeed doing this and am wondering if it is even possible through DIG1 and DIG2. Stop me if it isn't possible and I'll stop pulling my hair and losing sleep.
I'll provide screenshots as needed but to prevent superfluous screens that aren't supporting, I'll refrain. Any and all assistance would be greatly appreciated.
John
KC4LZN
Re: WINKEYER FSK RTTY
Thetis does not support hardware RTTY (or any hardware FSK), which is why there is no RTTY or FSK mode buttons. You have to use a configuration that supports AFSK.
KC4LZN
Post by KC4LZN »
w-u-2-o wrote: Sat Nov 15, 2025 5:28 pm Thetis does not support hardware RTTY (or any hardware FSK), which is why there is no RTTY or FSK mode buttons. You have to use a configuration that supports AFSK.
Ok, so it's more of a Thetis restriction and not a hardware restriction. Ok. I can see and understand that. Enough beaten on it and I can continue to use the AFSK.
John
Return to “Keys, Keyers, Paddles & Bugs”
