G2 Updated files and simplified update procedure
Trucker
Re: G2 Updated files and simplified update procedure
Post by Trucker »
I updated the FPGA in my Ultra just yesterday from Laurence's Github page.
No issues with the front panel display. Maybe a setting that your friend was using previously has changed?
https://github.com/laurencebarker/Saturn/tree/main/FPGA
syracusepro
Post by syracusepro »
I got V17 of the firmware. Trying to upgrade to V25, but there is no folder called Saturn/scripts.
Saturn is there, but within Saturn, there is no folder called scripts.
Thanks.
WB9HKO
Post by WB9HKO »
syracusepro wrote: Sun Nov 09, 2025 4:30 pm I got V17 of the firmware. Trying to upgrade to V25, but there is no folder called Saturn/scripts.
Thanks.
I also have V17 firmware in my non-display G2. I can easily enough create a "scripts" directory, just don't know where to go from there. I've watched @N4VFR's video quite a few times, but not I'm sure whether to start from the @LauerenceBarker github or the @KD4YAL github since the firmware is older and components are obviously missing.
Tom
WB9HKO
Post by WB9HKO »
Do I just need to create a local scripts directory, then copy the contents (*.sh's) of the script directory on Lauerance's github to my RPi4 and then execute "update-G2.sh" in terminal?
Then follow with the firmware update process to update the FPGA from v17 to v25?
laurencebarker
Post by laurencebarker »
I can't remember when the "scripts" folder was added but it is possible that you haven't pulled it in from git yet.
open a terminal window and type:
cd ~/github/Saturn
git pull
that should net you a scripts folder!
WB9HKO
Post by WB9HKO »
laurencebarker wrote: Mon Dec 01, 2025 9:17 am I can't remember when the "scripts" folder was added but it is possible that you haven't pulled it in from git yet.
cd ~/github/Saturn
git pull
Thanks, that bit worked great. I then ran only the update-G2.sh script, and looking through the log file it seemed to process everything ok. Unfortunately, the Flashwriter app does not seem to be among the desktop icons any more. There is just a text file (see pic). When I ran the P2app to re-check firmware, it says the firmware v17 (major version0) is not compatible because p2app requires major version = 1, so I may have a chicken and egg problem in that I can't flash the v25?
There is still a Flashwriter directory with what looks like everything in it. Do I just execute directly from there?
UPDATE: Rebooted the pi and Flashwriter was there on the desktop as it should be. I then ran the update to v25 with success.
Saturn p2app output - 1.jpeg (390.69 KiB) Viewed 989 times
WB9HKO
Post by WB9HKO »
Text file on desktop
Flashwriter text file on desktop - 1.jpeg (233.82 KiB) Viewed 987 times
Flashwriter directory - 1.jpeg (218.31 KiB) Viewed 987 times
Log file is also attached
saturn-update-20251201-091503.log
(56.64 KiB) Downloaded 52 times
laurencebarker
you can run flashwriter from its own folder:
cd ~/Saturn/sw_tools/flashwriter
./flashwriter
if there is no flashwriter application file:
make clean
make
WB9HKO
Post by WB9HKO »
laurencebarker wrote: Mon Dec 01, 2025 7:45 pm you can run flashwriter from its own folder:
./flashwriter
make clean
make
Thanks Laurence. I figured out to reboot the RPi and everything worked perfectly after that. Flashwriter app icon appeared, so I was able to upgrade to v25 on the FPGA also. Already made a few contacts today :-)
DO7DV
Post by DO7DV »
I successfully updated the FPGA to V25TTL using flashwriter.
In the source files there is a reference to a "command line tool" it was derived from. Where can I find this command line tool?
For a completley automated Anan-G2 update procedure the cli tool to program the FPGA should also be pulled into the /home/pi/github/Saturn folder.
I tried to create a new SD card for my CM4 with the most current "Trixie" release.
But I encountered problems when trying to build p2app. (everything else did compile correctly)
Below there is the output of make.
I suspect it has something to do with Trixie having libgpiod v2 (and gpiod 2.2), while in Bookworm you get libgpio v1 (and gpiod 1.6).
The new interface breaks compatibility.
Building a new SD card for CM4 with Bookworm does work.
Code: Select all
pi@raspberrypi:~/github/Saturn/sw_projects/P2_app $ make
gcc -c -o g2panel.o -Wall -Wextra -Wno-unused-function -g -D_GNU_SOURCE -D GIT_DATE='"3 Dec 2025 19:52:54"' g2panel.c
g2panel.c:100:8: error: variable ‘config’ has initializer but incomplete type
  100 | struct gpiod_line_request_config config = {"p2app", GPIOD_LINE_REQUEST_DIRECTION_INPUT, 0};
g2panel.c:100:44: warning: excess elements in struct initializer
g2panel.c:100:44: note: (near initialization for ‘config’)
g2panel.c:100:53: error: ‘GPIOD_LINE_REQUEST_DIRECTION_INPUT’ undeclared here (not in a function); did you mean ‘GPIOD_LINE_DIRECTION_INPUT’?
g2panel.c:100:53: warning: excess elements in struct initializer
g2panel.c:100:53: note: (near initialization for ‘config’)
g2panel.c:100:89: warning: excess elements in struct initializer
g2panel.c:100:89: note: (near initialization for ‘config’)
g2panel.c: In function ‘VFOEventHandler’:
g2panel.c:260:29: error: storage size of ‘Event’ isn’t known
  260 |     struct gpiod_line_event Event;
g2panel.c:265:21: error: implicit declaration of function ‘gpiod_line_event_wait’; did you mean ‘gpiod_edge_event_cop’? [-Wimplicit-function-declaration]
  265 |         returnval = gpiod_line_event_wait(VFO1, &ts);
      |                     gpiod_edge_event_copy
g2panel.c:268:25: error: implicit declaration of function ‘gpiod_line_event_read’; did you mean ‘gpiod_edge_event_fre’? [-Wimplicit-function-declaration]
  268 |             returnval = gpiod_line_event_read(VFO1, &Event);            // undocumented: this is needed to clear the event
      |                         gpiod_edge_event_free
g2panel.c:269:28: error: implicit declaration of function ‘gpiod_line_get_value’; did you mean ‘gpiod_line_request_get_value’? [-Wimplicit-function-declaration]
  269 |             DirectionBit = gpiod_line_get_value(VFO2);
g2panel.c:260:29: warning: unused variable ‘Event’ [-Wunused-variable]
g2panel.c: In function ‘G2PanelTick’:
g2panel.c:343:9: error: implicit declaration of function ‘gpiod_line_get_value_bulk’ [-Wimplicit-function-declaration]
  343 |         gpiod_line_get_value_bulk(&PBInLines, IOPinValues);
g2panel.c: In function ‘SetupG2PanelGPIO’:
g2panel.c:442:16: error: implicit declaration of function ‘gpiod_chip_get_line’; did you mean ‘gpiod_chip_get_info’? -Wimplicit-function-declaration]
  442 |         VFO1 = gpiod_chip_get_line(chip, 17);
      |                gpiod_chip_get_info
g2panel.c:442:14: error: assignment to ‘struct gpiod_line *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
g2panel.c:443:14: error: assignment to ‘struct gpiod_line *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
  443 |         VFO2 = gpiod_chip_get_line(chip, 18);
g2panel.c:445:9: error: implicit declaration of function ‘gpiod_line_request_rising_edge_events’; did you mean ‘gpiod_line_request_read_edge_events’? [-Wimplicit-function-declaration]
  445 |         gpiod_line_request_rising_edge_events(VFO1, "VFO 1");
g2panel.c:446:9: error: implicit declaration of function ‘gpiod_line_request_input’; did you mean ‘gpiod_line_request_get_fd’? [-Wimplicit-function-declaration]
  446 |         gpiod_line_request_input(VFO2, "VFO 2");
g2panel.c:449:9: error: implicit declaration of function ‘gpiod_chip_get_lines’; did you mean ‘gpiod_chip_get_info’? -Wimplicit-function-declaration]
  449 |         gpiod_chip_get_lines(chip, PBIOPins, VNUMGPIO, &PBInLines);
      |         gpiod_chip_get_info
g2panel.c:450:9: error: implicit declaration of function ‘gpiod_line_request_bulk’; did you mean ‘gpiod_line_request_get_fd’? [-Wimplicit-function-declaration]
  450 |         gpiod_line_request_bulk(&PBInLines, &config, IOPinValues);
g2panel.c: In function ‘ShutdownG2PanelHandler’:
g2panel.c:531:9: error: implicit declaration of function ‘gpiod_line_release’; did you mean ‘gpiod_line_request_release’? [-Wimplicit-function-declaration]
  531 |         gpiod_line_release(VFO1);
g2panel.c:533:9: error: implicit declaration of function ‘gpiod_line_release_bulk’ [-Wimplicit-function-declaration]
  533 |         gpiod_line_release_bulk(&PBInLines);
g2panel.c: At top level:
g2panel.c:99:24: error: storage size of ‘PBInLines’ isn’t known
   99 | struct gpiod_line_bulk PBInLines;
g2panel.c:100:34: error: storage size of ‘config’ isn’t known
make: *** [Makefile:31: g2panel.o] Error 1
laurencebarker
Martin CT1IQI has already reported the issue with newer kernels and libgpiod. Yesterday he sent me code to try, but I don't know yet if I can test it. If I can it won't be till next week because my access to the radio is blocked by visitors.
The command line flash programmer is available in ~/github/Saturn/sw_tools/spiload. I will need to work out the offset address that the flash device should be written to (it isn't zero, or the "fall back boot" process will be lost).
kd4yal
Post by kd4yal »
I’ve been running Raspberry Pi OS Trixie since its release and have developed several patches in my GitHub repo to address the issues I encountered getting Trixie working on the G2 CM module. I think the bigger long-term concern is how GPIO will be handled to maintain compatibility across OS versions. Also, please note that my patches have not been tested on an Ultra I have only tested with the (black face) unit.
https://github.com/kd4yal2024/Saturn/tree/main/scripts
I also have a Trixie image that’s currently being tested by several users. So far, the only issue being reported is IPv4 link-local (APIPA). It was widely expected that IPv4 link-local behavior would be “fixed” in Trixie, but reports still indicate cases where IPv4LL/APIPA is not assigned correctly, depending on the configuration and how NetworkManager is provisioned. I have a patch for this as well, but I’m continuing to validate it before publishing it to GitHub.
Jerry, KD4YAL
KD1GA
Post by KD1GA »
Thanks Jerry for posting this and all the help it's truly appreciated.
Vin KD1GA
ct1iqi
Post by ct1iqi »
@DO7DV
as Laurence already mentioned I found the same problem when compiling an OS for the upgrade with Radxa CM5.
Using the Armbian build system, kernel 6.18, and Debian Trixie. Got p2app to compile again by some edits to Makefile and g2panel.c
You can find them here:
https://cacelense.pt/G2/p2app_gpiod_v2
In Makefile you can choose either gpiod v1 or v2.
kd4yal
Post by kd4yal »
Thanks for sharing that, and yes — we’re converging on the same underlying issue.
For clarity, I have already implemented a more robust and forward-compatible solution in my GitHub repository, which includes conditional handling for libgpiod v1 vs. v2, build fixes, and a simplified update procedure that avoids breaking older images. That work has been running successfully on multiple G2 CM systems under Raspberry Pi OS Trixie.
However, those changes have not been accepted upstream, which is why different parallel solutions are now appearing. My approach was designed specifically to survive OS transitions (Bullseye → Bookworm → Trixie) with minimal churn and without requiring users to manually edit Makefiles or source files during upgrades.
It’s encouraging to see others independently arrive at similar conclusions — it reinforces that the root cause is well understood now. The remaining challenge isn’t technical so much as consolidation: agreeing on a single, maintainable upstream solution so we don’t fragment fixes across multiple repos and images.
For reference, my implementation and update scripts are here:
https://github.com/kd4yal2024/Saturn/tr ... cts/P2_app
I’m happy to compare approaches or help align things if there’s interest in merging efforts upstream. Long-term stability across OS releases should really be the goal here.
Jerry, KD4YAL
