Radio: Anan 7000DLE MkII
Software: Thetis 2.10.3.11
Problem: RX2 has significantly reduced sensitivity on 6 meters only. HF works correctly on both receivers.
Test Results:
Same antenna, same beacon signal: (Move 6m antenna from RX1 to RX2
• RX1: 6 µV
• RX2: <1 µV
(Approximately 15-16 dB difference)
What I've Verified:
• HF performance identical on RX1 and RX2
• DDC/ADC assignments checked — reset to default, no change
• 6m LNA enabled for RX (Disable unchecked)
• No per-band RX2 antenna settings
Also tried it with a new default DB
History:
RX2 6m sensitivity was previously equal to RX1. Problem appeared without known hardware changes.
Question:
Is there a Thetis configuration setting that could cause RX2-only sensitivity loss on 6m while HF remains unaffected? Trying to rule out config issues before investigating hardware.
- Board index Hardware & Software Interfacing Apache-specific Hardware Discussions
- Search
- It is currently Wed Feb 04, 2026 12:24 am
- All times are UTC
RX2 6m Sensitivity Loss — Was Working Previously
Jump to
- Apache Labs News
- ↳ Apache Labs News
- Client Software Discussion
- ↳ Thetis
- ↳ piHPSDR
- ↳ PowerSDR mRX
- ↳ linHPSDR
- ↳ SDR Console
- ↳ All Other Clients
- ↳ Digital ("Virtual") Audio
- ↳ Amplifiers & Tuners
- ↳ Transverters
- ↳ PC's & Homebrew Hardware
- Firmware Discussion
- ↳ Upgrading/Downgrading
- ↳ Orion Firmware (200D)
- ↳ Angelia Firmware (100D)
- ↳ Legacy Yahoo Group Files
- Other Topics
- Equipment Exchange
