CMD PL1 issue with ACG Level control
Having some weirdness. When I program a wheel for RX1 ACG Level In (or the one for RX2), the wheel will control the level in the GUI until I reboot. Then the wheel will just jump the sliders to a low value and not do any other control. Interestingly the LED surround of the wheel will track the slider level without an issue.
The wheels for Volume and Filter High and Low work fine, and work fine when physically mapped to the wheels I could not get to work right for ACG.
The only way I have been able to recover is to unmap the ACG function and then remap. But it is temporary and acts up again.
Re: CMD PL1 issue with ACG Level control
Found a way to recover but it is weird. I programmed 2 more wheels, Fil Lo and Fil Hi. When I start PSDR and the AGC level wheels do not work all I have to do is a slightly move either the Fil Hi or Lo and then the AGC Level wheel will work.
But have to do this every time I start PSDR.
Thoughts?
Thoughts?
Thanks for reporting this, Gary. I've been using both a PL-1 and a Micro, but I have the AGC levels mapped to sliders on the Micro, so I haven't noticed this. I mapped one of the PL-1 wheels to RX1 AGC tonight and can re-create your problem.
Strangely enough, if I have that AGC mapped to both a mini wheel on the PL-1 and a slider on the Micro, the slider works fine, the LEDs on the Micro do the right thing, but the PL-1 mini wheel itself misbehaves.
I'll have a look and hopefully have a fix soon.
Chris, W2PA
Chris, W2PA
Thanks Chris, I thought I was going crazy. Will be looking forward to the update.
While you were at fixing this issue could you add Drive Level to a Wheel function ???
Gary,
Are you talking about the CMD 2A? I am using it. I have the AGC RX1 programmed to the knob in the left rear. I find that occasionally on startup it will do as you describe and then when I look at the settings it has been changed to a wheel ... so I have to reprogram it as a knob. THis happens very rarely though. For the most part it works fine as a knob. I LOVE using the CMD 2A - works very well.
Gary I am using the CMD PL1. But Chris confirmed the issue and said he will fix it in a future release.
Chris, when do you think an update will be available?
Very soon, Gary. Stay tuned. Lots of other stuff in the next release, so there is a lot of testing going on.
Chris, W2PA
Chris, W2PA
Thanks for all your hard work Chris. 73, de WB4YAL
[Anan 200D
OpenHDSDR
Behringer CMD PL-1
[Anan 200D
OpenHDSDR
Behringer CMD PL-1
Apache Labs ANAN 8000DLE
