Some VERY basic questions below, but I want to pose them any way.
Q1: New desk-top or workstation caliber machines boast both SSD and HDD storage media. Will the Operating System (O/S) reside on the SSD by default? I know that one can port the O/S to SSD through cloning the HDD first, but I would rather not mess with that. I would prefer the O/S is on the SSD, not HDD and I don't know if I can make this assumption.
Q2: Ethernet speed is obviously KEY to operating SDR unless one goes for the new ANAN 7000DLE Mk2 with the PC basically incorporated. What would be a "reasonable" Ethernet speed you recommend?
Q3: Number of displays that one wants to plug in is another. I see that some of the newer machines boast "dual display support", but I am not exactly sure what that means? My 'el cheapo' dual-core i5 lap-top can have the built-in display "cloned" to an external display which I am availing myself of right now, but I would likely have 3 displays operating at once with any new PC that I acquire. Does that suggest the specs say "tri-display support?"
NOTE that I rely heavily on a PC for audio processing (I use Live Professor 2, a VST Host that has worked well for me and a plethora of VST 64 bit plug-ins). The Audio/USB Interface I use features a USB 2.0 port as well which is definitely not helping so another interface that has USB 3.0 in it is the other thing that I will be purchasing. I know there are other devices that are even faster but at this stage I am not going to splurge more than I absolutely need.
Awaiting your suggestions!
- NI2M
