Page 5 of 5
Re: GPSDO Tutorial?
Posted: Tue Sep 26, 2023 10:06 pm
by PaulManc
w-u-2-o wrote:200D, 7000, 8000, Andromeda, and G2 all use the same 10MHz input circuit. You should have no problem.
Forgive me for asking again, Scott.
What should the input impedance of the 10mhz ref input be is it 50ohms or something else? I plan to use the Leo Bodnar GPSDO
Cheers,
Re: GPSDO Tutorial?
Posted: Tue Sep 26, 2023 11:50 pm
The Bodnar is 50 ohm output impedance and the ANAN is high impedance as delivered from the factory. Nevertheless that combo should work just fine as is. You may have to adjust the Bodnar drive level.
Re: GPSDO Tutorial?
Posted: Thu Sep 28, 2023 12:41 am
by W9BHI
There is a 2 pin header on the board that places a 50 ohm termination on the external ref.input.
Re: GPSDO Tutorial?
Posted: Thu Sep 28, 2023 10:28 am
by KC2QMA
I have the one with the 2 10mhz outputs and this unit and works fine with G2.
It works with as little as 8mA of drive, outputs a square wave.
Just put the GPS antenna in your window or outside, connect GPSDO to radio via BNC to SMA cable to the 10mhz input on the back of the radio go into Thetis and enable External Reference and your done!
simple plug and play!
Re: GPSDO Tutorial?
Posted: Sat Sep 30, 2023 10:36 pm
by PaulManc
w-u-2-o wrote:The Bodnar is 50 ohm output impedance and the ANAN is high impedance as delivered from the factory. Nevertheless that combo should work just fine as is. You may have to adjust the Bodnar drive level.
As usual, BIG Tnx 73
Re: GPSDO Tutorial?
Posted: Mon Jan 22, 2024 7:18 pm
by KA9UVY
I have been experiencing since day one my Anan 7000DLE MKIII locking in two different places when powered on, I typically just run a calibration with WWV in Thetis to resolve the issue and it stays OK most of the time but very seldomly jumps back off again the correction or offset is to around 0.99997656 instead of 10.000001 or so.
Anyway I had purchased a Leo Bodnar GPS 10 Mhz source many months ago but with limited time to spend with my ANAN, I just hooked it up tonight.
My Results:
Radio is off frequency by this same margin when observing WWV but I cannot seem to enter a correction factor into HPSDR when use ext source is checked?
Pardon me for not seeing much of anything on here about using an ext source and still applying a correction factor in Thetis to get everything to be correct.?
Thetis defaults to 1.00000000 if I check the ext source and I can see the WWV carrier jump to the left of the center crosshair then my radio is clearly off frequency. It looks like I need a correction factor applied to my ext source to get this radio ON freq and hitting the reset button does nothing.
My Leo Bodnar software panel is pretty much exactly the same as the one posted earlier in this thread.
Please point me in the right direction. Thanks
Re: GPSDO Tutorial?
Posted: Tue Jan 23, 2024 10:40 pm
by W4WT
Robert, I assume you have tried adjusting the adjustment that is just below the option "Using ext 10Mhz ref" and not the "Correction Factor" adjustment when you have the GDO connected? I have a 7000 MK II and I use a GDO and have no trouble moving the "zero" around with the adjustment factor in the bottom left of the Calibration Tab. My correction is small but it did take just a bit to zero it to WWV with my GDO; 1.00000003. You shouldn't hit the reset button after entering your offset unless you want to clear it.
I'm assuming you have the Thetis version with this correction area in the Calibration tab. I don't remember which version it came out in. Before that version, there was only the "Correction Factor" window which I don't believe affected the external input at all.
Joe, W4WT
Re: GPSDO Tutorial?
Posted: Wed Jan 24, 2024 3:09 am
by KA9UVY
Hi Joe, Thanks for the reply, the version I am running is listed in my signature and I believe its the newest out or close.
My calibration section is as follows:
freq cal.jpg (135.84 KiB) Viewed 28647 times
When I check to use the external 10 Mhz Ref, It will not change if I move the correction factor up or down and it actually reverts back to 1.0000000
If I calibrate with WWV it adjusts and stays put but my radio sometimes jumps off.
I can't use my GPSDO at all with out a correction factor in HPSDR?
Re: GPSDO Tutorial?
Posted: Wed Jan 24, 2024 5:25 am
by W4WT
Robert, you may have already tried this but if not give it a go. Save your current database then reset the database and shutdown Thetis. Power cycle the radio then start Thetis. Put just the bare minimum setup info in to get the radio operating and then try the calibration routine again and see if anything changes. If it still fails, reload your database.
This actually sounds like a hardware problem to me. Assuming the database reset doesn't change anything, I would think that even more strongly.
You say it sometimes "jumps", I assume you mean it jumps frequency? If so, how much does the frequency change? Does it ever jump back?
Joe, W4WT
Re: GPSDO Tutorial?
Posted: Wed Jan 31, 2024 12:36 am
by W9BHI
I have a 7000DLE blue face and I am using a Trimble Thunderbolt GPS unit as an external 10MHz reference. It has a sine wave output that was a bit too high so I have the 50 ohm jumper installed on the Orion board and it is now within spec. Thetis is configured with the external 10 MHz enabled. I don't use any offsets because the GPS output is a near perfect 10 MHz and when I check against 10MHz WWV with the mode set to DSB and looking at the phase mode, it is right on frequency. Mind you that my radio was an earlier one that would not recognize a sine wave input on the 10 MHz reference input.
I had the radio in to Doug for a 12 meter output issue and while he had it on his bench, he changed a resistor value in the external reference detection circuit that fixed the issue with it not detecting a sine wave. He notified the factory about the issue and all units after that last run were using the recalculated resistor in that circuit.
Re: GPSDO accuracy and what the satellites are doing
Posted: Tue May 07, 2024 3:09 am
by VK4BXI
Tests that I've done imply that the 10MHz signals from the GPS satellites are changing frequency randomly by small amounts.
I've been using an "old" but very stable reference 10 MHz crystal oscillator which is in its own oven to supply the 10 MHz external reference to my 7000 mkII. For some reason or another I had doubt sown in my mind about its accuracy.
I found an old Datachron network time server which has a GPS disciplined 10 MHz reference and set that to work. I then purchased a GPSDO by VK4AMG (which is designed as a ultra stable reference for microwave use) and set that running.
Using the reference oscillator as an external trigger I then connected the two GPSDO's to the two inputs of my 100MHz scope.
I allowed everything to settle for a day or so and then looked at how the two traces were moving around. At times both traces were almost "rock" stable and moved together against the 10MHz crystal oscillator at a very low rate.....taking some 50 ~60 seconds to move a complete sine wave across the screen, indicating that my crystal oscillator was "spot on".
The surprise came when one or other of the GPSDO's abruptly changed frequency by about 0.05 to 0.1 Hz and stayed that way for a few minutes. At times both were "off" ....and in different directions. The changes appear to be "random".
I am coming to believe that either this is deliberate or a function of how the GPSDO's operate handing over from one satellite to another. I wonder if anyone else has noticed this or has an idea of what is going on ?
Bob
Posted: Tue May 07, 2024 10:42 am
VK4BXI wrote:Tests that I've done imply that the 10MHz signals from the GPS satellites are changing frequency randomly by small amounts.
I can assure you this is not the case. I have been deeply involved with the GPS and, in particular, GPS time and frequency standards, since before GPS reached it's Initial Operating Capability (IOC) in 1993.
Those interpretations are exactly backwards. The two GPSDO outputs moved together, which means they are doing what they are supposed to, which is to generate highly accurate and identical 10MHz signals. It's the crystal oscillator that was not as close to 10MHz as the two GPSDOs. Trigger off of the GPSDO and watch the crystal oscillator output "move". The fact that both GPSDOs were locked together is a clear indications things were working as they should be.
This is caused by a faulty or poorly designed GPSDO, and not any fault or design issue with GPS. Which GPSDO demonstrated instability, the Datachron or the VK4AMG unit?
There is no "hand over" in GPS, it does not work like a cellular radio system. As the constellation in view changes the solution for frequency will not change appreciably and if there are short time periods (seconds, not minutes) where a solution is not available (unlikely unless you are in deep urban or natural canyons) the short term stability of the oscillator that is being disciplined is sufficient to maintain a very high level of accuracy. And, in a properly designed GPSDO, that oscillator will start to drift in the absence of a good GPS solution, but it should NEVER jump.
Again, I can 100% assure you GPS time and frequency transfer are far superior to your crystal oscillator and there are no "random frequency changes". The same is true for all extant GNSS systems including BeiDou, GLONASS and Galileo. Your experiments need to use a GPSDO as the master reference, and it appears you have at least one bad or poorly designed GPSDO.
Re: GPSDO Tutorial?
Posted: Tue May 07, 2024 12:18 pm
by VK4BXI
I agree with you Scott....it shouldn't be happening.
I have changed the the trigger source around to check on other possiblities, but when you end up triggering from the oscillator and the two GPSDO's are moving in different directions at slow but similar speeds it can't be the oscillator causing that. The two GPSDO's are fed from the same aerial getting the same information/sats. My first thought was that someone was messing with the signals ....to lower the accuracy due to the ongoing war or something like that. I know that there is a lot going on with the GPS network that is not discussed.
I discovered this running the oscillator against just the one GPSDO and decided it must be the oscillator.....I then bought the second GPSDO and it got the same sort of results. I then ran both GPSDO's. I can get (relative to the oscillator) one GPSDO or the other moving either way or both moving the same way (but not at quite the same speed) or both moving in opposite directions. I would love to believe that the oscillator is at fault but cannot reconcil what I see.
Bob
Re: GPSDO Tutorial?
Posted: Tue May 07, 2024 2:31 pm
VK4BXI wrote:...the two GPSDO's are moving in different directions at slow but similar speeds it can't be the oscillator causing that.
Either one or both of the GPSDOs is either broken or a bad design. It's as simple as that.
I have two GPSDOs here, an older BG7TBL unit (Chinese, from eBay), and one from Leo Bodnar. They both keep perfect time and frequency (well, within a few milliHertz ;) ).
The intentional diminishment of GPS accuracy, called Selective Availability (SA), was discontinued in May 2000. I was directly involved in a major technical effort to support this decision.
While there are certainly aspects of GPS (and, undoubtedly the other GNSS services) that are spooky, the basic functionality of providing precise and accurate time, frequency, position and velocity are monitored both formally and informally by thousands and thousands of people around the world. University labs, surveyors in the field, pilots, the FAA, the list is endless. If something was "off" everyone would know about it instantly.
You are suffering from a classic affliction known as "Segal's Law" :D
Again, the problem is that one or both of your GPSDOs is/are screwed up. This must be the case, by definition, because the world uses GPS and if GPS had some problem, accidental or intentional, the world would know. If both GPSDOs were perfectly in lockstep, or at least damn close (milliHertz of difference--which is very difficult to measure, BTW), then you would not be suffering so.
If you really want to dive deep, the eevblog.com forum is THE place to go. They have lots of interesting discussions about time and frequency accuracy, like this one for example.
Re: GPSDO Tutorial?
Posted: Wed May 08, 2024 2:17 am
by VK4BXI
Well I didn't know there was actually a law relating to my issue " Segals law" but its true enough. All I wanted to do was to set up my oscillator (out of a serious GPSDO) to an accurate 10 MHz to use on my 7000 mkII.
It turns out that its not a simple task.
Neither of my GPSDO's are broken. They both appear to use the output of a DAC to control the voltage trim input of the OCXO. This means that the OCXO changes its frequency in discrete steps that are very small but measurable. So what I believe that I am seeing is the GPS switching the input to the DAC up and down by one digit because the actual required frequency is between the two levels. The average 10MHz frequency is very good indeed......the instantainous frequency can be back and forward by a few milli-Hertz depending on the logic level set.
So yes I'm suffering from Segals law. Both GPSDO's that have very good stability and frequency.....but their instantainous frequencys are slightly off and change at a random rate. Not good for the final trimming of my OCXO.
So now do I look for the next level in frequency accuracy...a rubidium standard or perhaps something that uses caesium ?
Bob
Re: GPSDO Tutorial?
Posted: Wed May 08, 2024 10:28 am
VK4BXI wrote:Well I didn't know there was actually a law relating to my issue " Segals law" but its true enough. All I wanted to do was to set up my oscillator (out of a serious GPSDO) to an accurate 10 MHz to use on my 7000 mkII.
Absolutely right. Welcome to the arcane world of metrology!
Yes, that's exactly how they work.
In a well-designed GPSO this process should be all but unnoticeable. For instance, take a look at this Allan Deviation plot comparing three different frequency references: two GPSDOs and a Cesium primary standard.
Frequency error is the reference frequency, 10E6 Hz, multiplied by the Allen Deviation. The plot shows short and long term performance, the X axis is the measurement interval ("tau"). In all cases the frequency error is around or better than 100 µHz.
Now it's time (Ha! A pun!) for another well-worn aphorism, "Better is the enemy of good enough." Sometimes also written as "Perfect is the enemy of good."
Although it would appear the Allan Deviation performance of the two "watches", the two GPSDOs, is not stellar, the question remains: are they good enough? I'd argue that they are more than adequate for HF radio. Either will keep the radio well below 1Hz of perfect. Even if you had access to a NIST-traceable and recently calibrated 5071 (to buy a used one will set you back north of $15K) the adjustment of the OCXO will drift off of that calibration quite rapidly.
Why not simply feed the radio with the output of the GPSDO that you have and like the best?
Re: GPSDO Tutorial?
Posted: Wed May 08, 2024 12:09 pm
by VK4BXI
All noted and accepted. I didn't want to use a GPS directly because having been hit (the house) by lightning twice over the years I'm rather allergic to having too many aerials connected in my shack. So having a OXCO not connected to the outside world was preferable. I could use a GPS yes but its another piece of cable to remember to disconnect at the end of each spell spent in the shack. I have one rule.... I don't leave the house without disconnecting all of the coax and removing all power to the equipment.
regards Bob
