One thing occurred to me is that using an amp and pure signal.....is there anyway of using the pure signal feedback signal to drive a meter and scaling it so that I can look at the actual station output signal ?
Regards Bob
Re: Thetis v2.9.0.8 - meters and then some more
Posted: Sun Apr 30, 2023 8:24 am
by DL2XY
Just calibrate your panadapter!
The value is roughly the attenuation of your coupler, maybe you have to adjust a few dB.
Scale the tx-display and make sure DUP is enabled.
Posted: Sun Apr 30, 2023 9:11 am
by VK4BXI
Thanks I'll give that a go !
Posted: Fri May 05, 2023 11:06 pm
by JJ4SDR
How do you make sure that a meter floats (perhaps that isn't the correct term as I want the meter to stick to the GUI) on top of the main GUI? When I switch from GUI to surf the net, the meter shows up but not the GUI. How do I avoid the meter showing up (with no Thetis GUI visible) when I am in "surfing mode?"
Posted: Sat May 06, 2023 1:46 am
by Trucker
In the upper right corner of the container there is a selection you can see that looks like a bulletin board pin. Clicking on it, you can cycle through different settings that allow you to pin the container where you want it to stay.
Posted: Sun May 07, 2023 9:52 pm
by JJ4SDR
Thanks Steve!
An update from Richie
Posted: Fri May 12, 2023 2:38 pm
Hello all:
Richie asked me to post this update on what he's got going on. He's pushing to get out another release before he takes a well-deserved summer break from development. Please read carefully below.
After the push to get the pre-release 2.9.0.8 out, with the meter stuff,
I have basically run out of real life free time to do anything at the
moment.
That being said :
1) I did start working on some housekeeping code a few weeks ago
relating to saving/loading meter config which I hope to finish in the
coming weeks. It will require people to re-lay out their meters, but it
fixes a bunch of orphaned data in the database related to deleted meter
containers. The side effect of this fix/change will be that it will fix
the DB import/export problem for the meter config.
2) I need to code up the import of PA data, which is somewhat related
and similar to 1)
3) I am tempted to change the directX use of the video component to be
shared between the spectral display and meter containers. This will
obviously need testing, but may fix a few issues that people are
reporting to me (privately).
4) try to catch up with some of the known issues posted to my github
To that end, I am unsure when I can complete this, it is probably a day
or so of coding for 1+2+3, but finding free time where I can get some
decent free time is proving to be an issue right now. I have other
things going on and radio/thetis slides down the priority list
unfortunately.
I will make a concerted effort to finish 1,2,3 before the end of the
month, but beyond that I can see myself stepping back again for the
middle of the year until autumn/winter arrives.
Posted: Fri May 12, 2023 3:29 pm
by Tony EI7BMB
Thanks for the info Scott
Posted: Fri May 12, 2023 7:34 pm
by w3ub
I am hoping Ritchie starts with (unless there is a good reason) the fork that Steve G7KLJ has, it seems like some good work was done there and it would be nice for things to come back together ...
Doug
Posted: Sat May 13, 2023 4:53 pm
by Tony EI7BMB
I was wondering about this too Doug
w3ub wrote:I am hoping Ritchie starts with (unless there is a good reason) the fork that Steve G7KLJ has, it seems like some good work was done there and it would be nice for things to come back together ...
Doug
Posted: Sat May 13, 2023 5:22 pm
by W1JA
I realize Richie has very limited time. And I am so thankful for the fantastic progress and improvements that he has made recently with regard to metering, containers, and UI flexibility and appearance.
But there are some bugs related to the handling of the RX2 VFO and its container. Perhaps they're already part of Richie's plans. I will try to explain below.
I made an RX2 (TRX2) container with "Vfo Display" in it. I will list the bugs, or behaviors that I think are wrong, below in bold text.
When I turn on RX2, the RX2 container appears, with "VFO A" and "VFO B" VFOs shown. I would have expected only one VFO to exist in the RX2 container, labeled "RX2." With RX2 active, I can tune around and see the RX2 frequency change in the "VFO B" section of the RX2 container. But there's a spurious VFO A section in the RX2 container.
When I turn off RX2, the RX2 frequency is transferred to the RX1 VFO B frequency. Instead, the RX2 frequency should stay with RX2, and not overwrite the RX1 VFO B frequency. If I turn RX2 back on, RX2 starts up, but the original RX1 VFO B frequency is not restored, and is lost.
If I set up a Split & MultiRX situation on RX1, and then turn on RX2, Split is turned off but the MultiRX button remains in an ON state. RX2 inherits the RX1 VFO B frequency, but the RX1 VFO Sub frequency changes to what seems to be a random frequency. (For example, the Split MultiRX test I set up was VFO A 7168.00, VFO B 7218.00. When I turned on RX2, the the RX1 frequency was transferred to RX2, and the RX1 VFOB frequency changed to VFO Sub at 7359.999 < I've no idea where that frequency came from.)
These behaviors seem incorrect and buggy.
Posted: Sat May 13, 2023 5:26 pm
Doug
I don't think that's going to happen. It appears this is an effort to wrap up work in progress and no more. That would create a lot more work because he'll want to review every change.
Posted: Fri May 19, 2023 2:49 pm
by Tony EI7BMB
my direct x error message woes suddenly re appeared today
Posted: Mon Jun 12, 2023 2:29 am
Hey all,
I have updated the github repo and made a final release of 2.9.0.8. If there are any big problems/gotchas let me know via github issues. Please read the change log. Invites to a few others have been sent out to my repo so fixes/changes can be made if needed.
I wont be doing any more to Thetis for a while, but will check in from time to time to see how things are going. My original changes started a few years ago with a friend asking for a quick modification, which seemingly spiralled out of control Also, many thanks to Ernst and others who have run 'in the works' versions, tracking and finding bugs/issues.
Thanks Richie for everything, I have been checking in on your Github Repo quite alot.
Thanks and 73's,
Posted: Mon Jun 12, 2023 3:36 am
by Trucker
Thank you Ritchie for sharing all your hard work. It is greatly appreciated.
Posted: Mon Jun 12, 2023 5:32 am
by liam
Hi Thank you Ritchie
Liam
Posted: Mon Jun 12, 2023 6:06 am
by rbduck
Richie, I'll join the choir and add my thanks to you as well. I know you put in some long and hard hours on Thetis. Thank you very much!
Posted: Mon Jun 12, 2023 9:02 am
by DH1KLM
And so do I. Thank you for your endless effort. I did a quick test on VSQL and I am amazed how well it works.
I hope you come back and doing your magic to Thetis again someday.
Thanks again and all the best.
Sigi
Posted: Mon Jun 12, 2023 12:25 pm
by w9ac
Riche,
Thank you for the many miracles you've performed over the last few years. Hope to work you on the bands one day.
Posted: Mon Jun 12, 2023 3:31 pm
by Trucker
DH1KLM wrote:And so do I. Thank you for your endless effort. I did a quick test on VSQL and I am amazed how well it works.
Sigi
Agree 100%. The VSQL (Applied lightly) plus NR2 is as close to full quieting FM as you can get on HF SSB. This addition from Warren Pratt to his WDSP library is simply amazing.
I don't see how it could be topped.
Thanks again Ritchie for activating this feature to the Squelch in Thetis.
Posted: Mon Jun 12, 2023 5:29 pm
by Trucker
I have encountered something I wasn't expecting with this version. There are thunderstorms north of me (About 40 miles ) and I can clearly see the static crashes on the panadapter. But,,,,,,with the Voice Squelch enabled along with NR2, I don't hear them in the audio!
The net I have been listening to sounds like people sitting in the room with me and talking.
I have never had anything work like this on HF SSB before.
Sorry to carry on, but this really is amazing to me.
Posted: Mon Jun 12, 2023 5:52 pm
I had the distinct pleasure of working with Warren on the design of the voice squelch. I'm on the road right now and away from a real keyboard, but when I return I will provide a more detailed description of the DSP involved and provide some guidelines for it's use.
Much like NR2 I believe this is the only implementation available in amateur radio outside of using commercial gear. Thetis and its developers continue lead the way!
Posted: Mon Jun 12, 2023 7:03 pm
by W7GES
I would like to add my thanks for the work you have done with Thetis.
Hope your summer goes well and you get some rest and relaxation.
George / W7GES
Posted: Tue Jun 13, 2023 1:08 am
by KC1LKO
Thank you Richie for your generosity and contributions and for the style in which you did it. Hope you enjoy your journey wherever it takes you.
Miguel
KC1LKO
Posted: Tue Jun 13, 2023 2:59 am
by Roturbo
I also want to thank´s Richie and all the others involved on the project, Thetis is one amazing peace of
software, but we need to adjust and use it correctly.
I have make a small video with Voice Squelch in action,, and i can tell you,, i still didn´t get use to it,
the "sound" of silence is strange, it is like the radio just turn off or the VAC have gaps,,, just amazing.
I also have other videos with Thetis on my channel.
Regards.
Posted: Tue Jun 13, 2023 12:54 pm
Not sure if this is the correct place to ask this, but does Richie's latest 2.9.0.8 Release incorporate any of Steve's G7KLJ improvements, and/or vise versa?
Put differently, are there now two distinct and separate branches of Thetis, neither of which include any of the recent enhancements incorporated in the other branch?
And if that's the case, then going forward, will the typical Thetis user likely have to decide up-front which branch of Thetis he will align his operations with, at the cost of painting himself out of the unique features offered by the other branch?
Just trying to plan for the future.
Posted: Tue Jun 13, 2023 1:33 pm
by Joe
Mark,
Great question, I apologize if this is the wrong place for this, also. But, both versions, etc. have great updates/upgrades and are very much appreciated. It would be great to get the best of both versions incorporated into one, if possible. Anyway, thanks to all for the work with Thetis.
73’s
Posted: Tue Jun 13, 2023 2:13 pm
by Jim
Installed the final 2.9.0.8 64 version and the new VSQL is really nice.
Couple of items observed.
(1) Thetis resolution off when opening to full screen. Reminds me of old CGA. Clicking RX2 on and off reverts it to normal or clicking to reduced screen size and back to full screen. Never seen this going back several years using Thetis or PowerSDR. Wish I could figure this one out but at least we have a work around.
(2) My tune slider missing. Copied my skins from the 2.9.0.8 64-bit beta into this final version and now the tune slider is back in place.
(3) All 60-meter 5 channel presets off by 100 hz and unable to change screen resolution off 1X. Opening 60-meter band stacks, going to options, unlocking and editing each channel to proper frequency and changing screen to .5x (my preferred) on each channel locking each one and now all is well. Using .5x I have one view of all 5 channels. Thinking about this I may have also had to do this on the beta version or even earlier versions?
73 de KE4WY JIM
Posted: Tue Jun 13, 2023 2:53 pm
by Trucker
I think some of the issues people are seeing and having to correct, are related to changes in the way settings etc are stored in the database. Ritchie mentioned in his post and on Github that things like Meters and their settings would have to be redone. I experienced that. Once I added Meters back to Thetis, they and their settings stay. ( and come back on restart)
It is possible the changes have effected other settings as well.
