Page 59 of 59
Posted: Sat Apr 02, 2022 7:24 pm
by NC3Z
In Appearance > RX Display > Grid > Background the Alpha slider no longer works with Disable picDisplay is clicked.
Posted: Sat Apr 02, 2022 7:27 pm
by NC3Z
Panadapter Gradient may not be working either.
Posted: Sat Apr 02, 2022 7:44 pm
remove the links a moment, whilst I check this out.
Posted: Sat Apr 02, 2022 7:52 pm
by NC3Z
ramdor wrote:remove the links a moment,
No problem, I just had noticed as my panadapter display was a bit different.
Posted: Sat Apr 02, 2022 8:08 pm
Ok, post1 updated again, it is still 21k9c however.
Hopefully that fixes it. Caused by the alpha mode change needed to get anything working with VirtualBox, but now has been reverted.
Posted: Sat Apr 02, 2022 8:24 pm
by NC3Z
Working now Richie. Won't even ask why in the world someone would want to run this in a VirtualBox, seems counter productive to keeping Thetis high performance.
Posted: Sat Apr 02, 2022 8:27 pm
I don't know either, but interestingly enough Gary, it ran great with one exception, the display of the waterfall
Posted: Sat Apr 02, 2022 11:11 pm
by w2ner
NC3Z wrote:Working now Richie. Won't even ask why in the world someone would want to run this in a VirtualBox, seems counter productive to keeping Thetis high performance.
There’s a very good reason why someone would. If someone only uses a Mac, you have no choice but to use one like Parallels, and by the way has very little impact on performance if setup correctly.
Posted: Sun Apr 03, 2022 9:06 am
by Tony EI7BMB
All good here, thanks Richie
ramdor wrote:Ok, post1 updated again, it is still 21k9c however.
Posted: Sun Apr 03, 2022 12:20 pm
by ULTIMAX
Hello Richie, all working so good here, thank you so much for the Ignore SEQ errors Box
Thank you for all your work.
Al
73'
Posted: Sun Apr 03, 2022 5:49 pm
by I2NOY
Hi Richie, following mod in 21k9c broke the CAT communication between Thetis and my SPE Expert 1.5K v2 linear amplifier:
-change: KenwoodAI command broadcast functions moved into delegate system
I am back to 21k9b and CAT is working now.
The connection between PC and SPE Expert is done by an USB to RS-232 dongle by FTDI
Posted: Sun Apr 03, 2022 8:12 pm
I2NOY wrote:Hi Richie, following mod in 21k9c broke the CAT communication between Thetis and my SPE Expert 1.5K v2 linear amplifier:
yes issue found in the formatting of the FA/FB strings related to the AI 'broadcast' in 21k9c
Please try 21k9d(pre) x64 :
https://bit.ly/377QcQO
[md5:536AFD7815C01408FCA044E380C21E48]
Posted: Mon Apr 04, 2022 1:07 am
With the formal release of 2.9.0 this topic is being closed.
You can find the successor topic for discussion of 2.9.0 bugs and other issues here:
https://apache-labs.com/community/viewt ... f=9&t=4132
