2.7.0
Locked
DG9FDA
Re: 2.7.0
Post by DG9FDA »
Hello Marcus,
this is the trick! Thank you for this hint! Now I am waiting for a reply to my second problem with the Filter tab...
73 de Georg, DG9FDA
Anan 100D first edition, Thetis v2.10.3.6 x64, Protocol 2 Version 12.1.8
FM5GB
Re: 2.7.0
Post by FM5GB »
Hi Georg,
remember to utilize DDUtil v 3.2.5 and connect your radio to your computer & the amp to your computer (as explained in the amp manual) so you can automatically control your drive level in Thetis by band. So you never overdrive your 1K-FA.
I've been utilizing this procedure since I got my Flex 5000A almost 10 years ago. DDUtil is to be downloaded on k5fr.com. It works for legacy Flex radios and has always been good for Anan radios operated thru PowerSDRmrx or Thetis. Later versions after 3.2.5 do not work being only suitable for Flex signature radios (6000 series).
Maybe you already use this configuration. If not I could give you a hand to fix it if needed.
73s Phil FM5GB
DG9FDA
Re: 2.7.0
Post by DG9FDA »
Thank you Phil, I will try when I find the time...
73 de Georg, DG9FDA
Re: 2.7.0
Where is source repository for your code?
Re: 2.7.0
2.6.9 is here, not sure where 2.7.0 is...
https://github.com/TAPR/OpenHPSDR-Thetis
PD3LK
Re: 2.7.0
Post by PD3LK »
2.7.0a3 is here.... https://www.dropbox.com/s/8ik72kfeqycex ... 3.zip?dl=0
unpack the files into your Thetis installation map. (overwriting the 2.6.9 files)
Don't forget to make a backup before doing this.
73 PD3LK
DH1KLM
Re: 2.7.0
Post by DH1KLM »
From my knowledge, these are the most recent sources.
https://github.com/w5wc/Thetis
Dave30019
Re: 2.7.0
Post by Dave30019 »
Where is the latest firmware for Thetis 2.7a3? Is there a list of fixes the different firmware versions address?
Dave
k4em
Re: 2.7.0
Dave30019 wrote:Where is the latest firmware for Thetis 2.7a3? Is there a list of fixes the different firmware versions address?
Easiest way to find them is to go to the firmware discussion:
https://apache-labs.com/community/viewt ... =32&t=3192
rbduck
Re: 2.7.0
Post by rbduck »
Go to the section Upgrading/Downgrading and read the first topic. It contains links to the firmware areas.
Re: 2.7.0
All,
Closing this topic. Please continue the conversation in the new Thetis 2.8.6 topic.
Locked
