Page 7 of 7
Re: 2.7.0
Posted: Sun Jun 28, 2020 2:20 pm
by DG9FDA
Hello Marcus,
this is the trick! Thank you for this hint! Now I am waiting for a reply to my second problem with the Filter tab...
73 de Georg, DG9FDA
Re: 2.7.0
Posted: Mon Jun 29, 2020 12:49 am
by FM5GB
Hi Georg,
remember to utilize DDUtil v 3.2.5 and connect your radio to your computer & the amp to your computer (as explained in the amp manual) so you can automatically control your drive level in Thetis by band. So you never overdrive your 1K-FA.
I've been utilizing this procedure since I got my Flex 5000A almost 10 years ago. DDUtil is to be downloaded on k5fr.com. It works for legacy Flex radios and has always been good for Anan radios operated thru PowerSDRmrx or Thetis. Later versions after 3.2.5 do not work being only suitable for Flex signature radios (6000 series).
Maybe you already use this configuration. If not I could give you a hand to fix it if needed.
73s Phil FM5GB
Re: 2.7.0
Posted: Tue Jun 30, 2020 7:56 am
by DG9FDA
Thank you Phil, I will try when I find the time...
73 de Georg, DG9FDA
Re: 2.7.0
Posted: Sun Jul 26, 2020 8:53 pm
by w9mdb
Where is source repository for your code?
Re: 2.7.0
Posted: Sun Jul 26, 2020 9:37 pm
2.6.9 is here, not sure where 2.7.0 is...
https://github.com/TAPR/OpenHPSDR-Thetis
Re: 2.7.0
Posted: Mon Jul 27, 2020 7:06 am
by PD3LK
2.7.0a3 is here....
https://www.dropbox.com/s/8ik72kfeqycex ... 3.zip?dl=0
unpack the files into your Thetis installation map. (overwriting the 2.6.9 files)
Don't forget to make a backup before doing this.
73 PD3LK
Re: 2.7.0
Posted: Mon Jul 27, 2020 10:48 am
by DH1KLM
From my knowledge, these are the most recent sources.
https://github.com/w5wc/Thetis
Re: 2.7.0
Posted: Tue Aug 25, 2020 11:15 am
by Dave30019
Where is the latest firmware for Thetis 2.7a3? Is there a list of fixes the different firmware versions address?
Dave
k4em
Re: 2.7.0
Posted: Tue Aug 25, 2020 11:35 am
by NC3Z
Dave30019 wrote:Where is the latest firmware for Thetis 2.7a3? Is there a list of fixes the different firmware versions address?
Easiest way to find them is to go to the firmware discussion:
Re: 2.7.0
Posted: Wed Aug 26, 2020 7:35 pm
by rbduck
Go to the section Upgrading/Downgrading and read the first topic. It contains links to the firmware areas.
Re: 2.7.0
Posted: Thu Oct 08, 2020 6:15 pm
All,
Closing this topic. Please continue the conversation in the new
Thetis 2.8.6 topic.
