Page 8 of 9
				Re: cmASIO feature in Thetis
				Posted: Mon Jan 15, 2024 8:04 am
				by StefanoAlvaro
				W4WMT wrote:StefanoAlvaro wrote:Could it be that the cmASIO functionality only works with protocol2?
Hi OM,
Yes, that is correct, cmASIO is not supported by protocol_1.
I'll have to check why the icon is still green using protocol 1 (I thought we tested that).
As far as not being able to run protocol_2 on your MKIII, have you checked out all of Rick's N1GP firmware builds for that FPGA?  He has quite a few, you might get lucky!
Bryan
Thanks Bryan, I imagined it was like this because with the same procedure on the p2 everything worked immediately.. Patience.
Regarding the fw there is nothing yet for my 5CEFA, only one works well at the beginning (21.7) but after a few minutes of TX it starts to give problems, regardless of the temperature.
Is there a possibility of operation in the future with the p1 and cmASIO?
				Posted: Mon Jan 15, 2024 9:54 am
				by W4WMT
				StefanoAlvaro wrote:Thanks Bryan, I imagined it was like this because with the same procedure on the p2 everything worked immediately.. Patience.
Too bad about your 5CEFA rig.  Mine is the same, none of the available firmware builds will run correctly.  I keep hoping Rick will have another brainstorm
Due to the single-threaded nature of protocol_1, it will never be able to support the high-performance requirements of cmASIO.
Bryan
				Posted: Mon Jan 15, 2024 10:21 am
				by W4WMT
				w-u-2-o wrote:Bryan: why can't cmASIO follow the buffer size set by the device driver?
The ChannelMaster native audio buffer size is 64 sample frames, it's hard-coded that way from stem to stern, with no provisions to change.  So, the expectation is that the hardware ASIO device driver for the host sound interface will conform to 64 samples to mesh with ChannelMaster.
AFAIK, the only ASIO driver that doesn't automatically comply with this is the Voicemeeter driver, which is a virtual driver, not a hardware driver.  Due to performance issues, cmASIO does not support virtual ASIO drivers.  YMMV,
Bryan
				Posted: Mon Jan 15, 2024 11:39 am
				And yet it works fine with Voicemeeter. What performance issues?
				Posted: Mon Feb 12, 2024 12:25 am
				by Dan
				First I would like to say thank you to Riche and Bryan for all your hard work. Thank you also to every one who have tested and figured this all out. No small number of us have benefited from your knowledge. As an example, I went in and easily configured it, and it worked correctly the first time and I am very delighted.
Now to my question, is it possible to use Pure Signal with cmASIO? The “Feedback” and “Pure Signal2” bars have stayed grayed out since I enable cmASIO.
Thank you for you help.  Dan KM6CQ
				Posted: Mon Feb 12, 2024 12:40 am
				by W4WMT
				Hi Dan,
Pure Signal works fine with cmAsiO, no differently than it does when using the microphone socket on the Anan.
Are you sure that the PS-A control is engaged in the Thetis console?
Bryan W4WMT
				Posted: Mon Feb 12, 2024 12:44 am
				by Dan
				Unbelievable Bryan, it was right in front of me and how long have I been using PS? uhggggg Sorry to bother you.
These are my two favorite features in Thetis.
Thanks, Dan
				Posted: Mon Feb 12, 2024 4:21 am
				by radiotx
				If I want to use cmASIO as an 'analog-to-digital' bridge for my rack audio gear. What settings need to be altered in Thetis to make sure no additional audio signal processing is occurring? The settings below were suggested by w-u-2-o to disable processing when plugged directly into the anan via 'mic/line in' with my analog signal. Thanks!
1. COMP, VOX, downward expander (DE) and transmit EQ (TX EQ) via the buttons on the main UI.
2. Everything on the Setup > DSP > CFC page.
3. The leveler on the Setup > DSP > AGC/ALC page, and also set ALC max. gain to 0dB.
				Posted: Mon Feb 12, 2024 11:11 am
				It's the same list no matter what input is selected: mic, line, VAC, cmASIO.
				Posted: Mon Feb 12, 2024 12:13 pm
				by radiotx
				w-u-2-o wrote:It's the same list no matter what input is selected: mic, line, VAC, cmASIO.
Got it. Thanks again!
Clif
KI5RLR
				Posted: Mon Feb 12, 2024 11:39 pm
				by Chiron
				I'm using Protocol v2 with 7000DLE MK2.
My pc is a laptop with an Realtek audio chip onboard.
There is no ASIO driver on the laptop.
So I searched and found an Realtek ASIO driver on the Dell website.
The Realtek ASIO driver can be configured via the Voicemeeter System settings/ Options page, when the Realtek ASIO driver is selected as A1 Hardware OUT at the main screen.
When you are at the System settings / Options page, you can select the high-lighted 'ASIO: Realtek ASIO' at OUT A1 Main Device and a Realtek ASIO Control Panel is popping-up.  Here you can set the delay (buffer) to minumum of 2ms. The Sample rate is set at 48000Hz and the buffer is set to 160. Also voicemeter is showing these values.
The smal program 'hostsample.exe' , gives the same info about Voicemeeter Virtual ASIO. 48000 sampleRate and 160 ASIOGetBufferSize.
In Regedit is Voicemeeter Virtual ASIO set as ASIOdrivername.
And unfortunate, Thetis is not giving a green cmASIO but red. This has probebly to do with the to high latency
The Realtek ASIO driver can't go lower to 64 clocks......
Unless I buy an external USB sound device that supports ASIO latency as low as 64 clocks, I guess ASIO audio with cmASIO will be unpossible.
				Posted: Tue Feb 13, 2024 1:07 am
				by W4WMT
				Hi Chiron,
There's no need to run Voicemeeter in your case, so long as the Realtek ASIO driver can meet the basic requirements of cmASIO.  Take a look at the cmASIO guide in the Windows start menu under OpenHPSDR and begin there.  If you don't know the precise name of the Realtek ASIO driver, you can download the hostsample.exe utility (linked in the guide) and post the results here for assistance.
Bryan W4WMT
				Posted: Tue Feb 13, 2024 1:29 am
				by Chiron
				W4WMT wrote:Hi Chiron,
Bryan W4WMT
Hello Bryan,
Thanks for your quick response.
Yes I know that Voicemeeter is not needed. But there are 2 reasens for me to use Voicemeeter.
1. The only way that I know to get into the Realtek ASIO driver configuration, is via Voicemeeter. There is probbably another way, but not known by me.
2. I use Voicemeeter to transport also some audio over Network via VBAN of Voicemeeter. So I already used it, and are able to set the latency/delay to the lowest alowable value of the Realtek ASIO driver.
Unfortunately, seems the Realtek chip limited due to too high minimum alloweable buffer size. And can not meet the basic requirements of cmASIO.
If you think that the limitation is the ASIO driver and not the audio chip, I would love to have the better ASIO driver.
Chiron PA3GHM
				Posted: Tue Feb 13, 2024 2:01 am
				by W4WMT
				Chiron wrote:Unfortunately, seems the Realtek chip limited due to too high minimum alloweable buffer size. And can not meet the basic requirements of cmASIO.
You will not know that for sure, until you run hostsample.exe to get hard results from the actual Realtek ASIO driver on your machine.
				Posted: Tue Feb 13, 2024 4:28 pm
				by Chiron
				W4WMT wrote:Chiron wrote:Unfortunately, seems the Realtek chip limited due to too high minimum alloweable buffer size. And can not meet the basic requirements of cmASIO.
Hello Bryan
You probably mist it, but i mentioned in my first reply:
Yes i did use hostsample.exe . The program concluded as mentioned that the lowest ASIO BufferSize is 160.
Yesterday i found a used UPHORIA UMC202HD. I hope to receive it this week. Then i can test cmASIO.
				Posted: Tue Feb 13, 2024 6:33 pm
				by Trucker
				I think you will like the Behringer results much better.
				Posted: Thu Feb 15, 2024 6:40 pm
				by Chiron
				Trucker wrote:I think you will like the Behringer results much better.
Hello James,
I just received the UMC202HD
This setup with UMC works good in combination with Thetis and cmASIO.
cmASIO icon in Thetis is green, and PureSignal works, VAC1 and VAC2 are not used.
I only need to start tuning the Block size in the registry to see how low I can go.
PA3GHM
				Posted: Thu Feb 15, 2024 10:30 pm
				by W4WMT
				Chiron wrote:I only need to start tuning the Block size in the registry to see how low I can go.
Each block is only worth 1.3 ms.
				Posted: Fri Feb 23, 2024 6:28 pm
				by n2gq
				Presonus Studio 26c and Voicemeeter Potato work really well together.
				Posted: Thu Feb 29, 2024 1:05 am
				by vk6cpu
				Would it be possible to update the CMASIO Guide and list the basic pre-requisites to be able to use this feature.
Namely your ASIO driver must be capbale of running with a buffer size of 64 (bits or bytes?).
YOu can see whether your ASIO drivers meet this requirement by running the hostsample.exe which lists the parameters of the various drivers. EG
ASIO driver: [0] = Realtek ASIO
asioVersion:   2
driverVersion: 3
ErrorMessage:  No ASIO Driver Error
ASIOGetChannels (inputs: 2, outputs: 2);
ASIOGetBufferSize (min: 1024, max: 1024, preferred: 1024, granularity: 0);
ASIOGetSampleRate (sampleRate: 0.000000);
ASIO driver: [1] = RODE AI-1 ASIO
asioVersion:   2
driverVersion: 1
Name:          [RODE AI-1 ASIO]
ASIOGetBufferSize (min: 64, max: 2048, preferred: 128, granularity: -1);
ASIOGetSampleRate (sampleRate: 48000.000000);
IF using via VOICEMEETER the Output CHannel must also be capablle of running with a 64 Bit Buffer.
This info upfront could save some users a workd of pain and dredging thru this 8 page thread.
Thanks for the work BTW.
				Posted: Thu Feb 29, 2024 9:16 am
				by W4WMT
				vk6cpu wrote:Would it be possible to update the CMASIO Guide and list the basic pre-requisites to be able to use this feature.
The basic prerequisites (there's only three) are at the bottom of the sheet.
				Posted: Sun Mar 03, 2024 10:14 pm
				by Chiron
				I'm using cmASIO now for a week with the use of VOX. It works realy perfect.
The tx to rx switching is high speed. When there is a small pause in my talking, you can hear if there is some other activity on the frequency. For example when doubling with another station.
This is a nice achievement for an SDR. My compliments to the involved team.
It was worth the investment of the Beahringer UMC202HD.
Regards,
Chiron
Chiron wrote:Trucker wrote:I think you will like the Behringer results much better.
Hello James,
PA3GHM
				Posted: Wed Mar 06, 2024 12:54 am
				by Dan
				Thank you Riche and Brain for cmASIO.
It is working very well on the 7000DLE MKII.
I use a Hermes Lite 2+ frequently to keep hours off the Anan.
The HL2 is protocol 1 only. At this time I simply got to regedit and change one character on the "ASIOdrivername" file. This prevents Thetis from seeing it when using the HL2. It looks like this "dASIOdrivername" d is for disabled.  Then I have access to the UMC204HD. (UMC ASIO Driver)
When I run the Anan I change it back, unless I want the UMC ASIO Driver available for VAC 1.
So I had to tell you all that just to tell you this, it would be very handy to have a Enable/Disable button in Thetis.
I think this would benefit those using Thetis for Anan and Hermes lite 2.
Thank you for your consideration, I appreciate everything the both of you do. Excellent work.
Best regards, Dan KM6CQ
				Posted: Sun Mar 31, 2024 10:22 pm
				by gw0hyu
				GW4NNO wrote:Thanks very much for that info Bryan. Not good from my point of view though. Think I'll stick as I am with cables hard wired from my interface to the line in and speakers out on the Anan.
Terry. GW4NNO
Hi Terry,
Have you explored setting Thetis  to use  Windows WASPI driver with your RME UFX ( I also have the UFX Mk 3) . You need to turn on Software Looback in RME TotalMix for your chosen hardware output channel and then you will see that channel (analogue or DAT)  opton in Thetis VAC input / output  drop down box.
Then fade up which ever RME hardware input , or if using a DAW a software playback channel (I use Reaper) and bingo you will be routing your physical hardware output to ethernet , latency is virtually (pun intended) nonexistent and audio quality (IMHO) cannot be surpassed!
Keith
				Posted: Tue Jun 04, 2024 7:09 pm
				by w3ub
				Perhaps this is buried in the thread somewhere, if you do not set a registry entry for ASIOblocknum, does it default to 5 somehow?
If we set an entry and try to reduce it, what issues are we trying to observe if it is set too low? Subjective audio issue, or the cm indicator turning red ... something else?
Doug
				Posted: Tue Jun 04, 2024 9:38 pm
				by W4WMT
				Hi Doug,
Yes, the default ring-buffer size is 5 sample blocks.  The ASIOblocknum registry key value is there for situations where 5 is not adequate.  If you reduce it too low, you'll get obvious audio artifacts as audio samples are being lost.
Bryan W4WMT
PS - I should add that the default of 5 was reached empirically over a year's stretch of testing by volunteers.  This was done before the introduction of the Saturn board and the Anan G2 models.  There is early evidence that, for the Saturn,  the default of 5 may be too low,
				Posted: Wed Jun 05, 2024 12:05 pm
				by w3ub
				Thanks, that is what I thought. Since each sample block is 64 bits, I assume that our audio interface ASIO buffer setting must match that, in other words there is no benefit in reducing it. Or in increasing the sample rate above 48k.
My setup is a UMC202HD directly to the 7000DLE Mk II.
Doug
				Posted: Wed Jun 05, 2024 7:18 pm
				by w3ub
				Looking at the UMC options panel (I am new to this ...) it will always go to 48k sample rate and 64 buffer size. So, those seem fixed.
There is an option to uncheck "Safe Mode", doing this reduces the output latency reported by the UMC control panel from 144 samples down to 48 samples, saving 2 msec of latency.
For my setup, it seems to work OK without Safe Mode checked, and I can run the AISOblocknum all the way down to 1 and everything seems OK. At least with minimal testing so far. I guess I'll run it like this for a while and see if there are any audio issues.
Again, UMC202HD directly to Anan7000DLE Mk II.
Doug
				Posted: Thu Jun 06, 2024 6:50 pm
				by w3ub
				I tried Lockmode, but that produces some issues.
My only question, is a value of 1 valid and the lowest possible for ASIOblocknum? One post earlier seemed to imply that a value of 2 was the lowest option. Or does it go all the way down to 0?
Doug
				Posted: Thu Jun 06, 2024 10:15 pm
				by W4WMT
				Hi Doug,
You are free to set ASIOblocknum to 1 or 0, but the minimum size of 2 is enforced by the code in WDSP anyway.  So, a setting of 2, 1, or 0 will all result in the same number of sample blocks being held by the ring-buffer - namely two.
Bryan W4WMT
