SPE Expert Amp Interfacing
K7ONY
Re: SPE Expert Amp Interfacing
Post by K7ONY »
I had thought the band data came from the open collector port on the Anan.
It can come from there, but only if you laboriously program the OC Control pins properly in Thetis setup and build a much more complex cable. Why go to all that trouble?
Newbee question here.... I was going to try to run my new 7000 remotely on occasion. Wouldn't I need to have the radio port work directly with the amp under that circumstance? I have started out with PowerSDR instead of Thetis as it was referenced in the op manual. How hard is it to program this functionality? Where would one look into to do this?
Thanks, 73
Tony . N7ZS
Tony,
All the smarts and most of the DSP reside in the software, either PowerSDR or Thetis. It's the software that runs the amp, not the box. The box you call a "radio" by itself is no such thing. It's merely the "RF unit" part of the radio. The only interface on the box that you could use to run the amp are the OC outputs.
When you say "remotely" do you mean in the house on the same LAN, hardwired, not Wi-Fi, or do you mean over the internet? If you mean in the house then no problem. Search on "serial device server" on Amazon or eBay. Attach that to the amp. Put the drivers on the PC. Bam! You've got a serial port on your PC that runs over the network.
K7ONY
Post by K7ONY »
I would be trying to run it remotely over the internet from somewhere else.
My radios are set up to send a cat signal to my SPE Expert amp whether I use it at my bench or remotely from where ever. The amp turns on with the radio. It also selects to proper antenna based on the band/frequency of the radio and follows the radio frequency where ever I tune the radio to.
The built in SPE amp tuner automagically remembers the tune setting for the part of the band being used with whichever antenna it was set to use. If one uses a steppIR then the amp can also send a cat signal to the antenna controller to have it tune to the proper band/frequency. I only need to remote into the radio, generally a little Icom 7100.
For the sake of super easy, I use RemoteHams.com, RCForbes server and client software on the Icom 7100. It is easy to remote in and talk on HP any band or freq.
Anyway, this is the CAT control functionality(local or remote), I was hoping to replicate with the ANAN. I was told it was easy to set up as a remote... like a flex.... I really haven't looked into that aspect.... just working on the amp interface right now.
K7ONY wrote:I would be trying to run it remotely over the internet from somewhere else.
This is not a problem. Since you must provision a PC running Thetis local to the ANAN the SPE interface will simply be the serial port arrangement on the Thetis PC already discussed above in this topic.
And this is exactly how it will work using the serial port connection to the Thetis PC as described above in this thread.
You will probably wind up using RCForb to remotely control Thetis as well, perhaps with an ancillary screen sharing app like TeamViewer to look at the Thetis UI. Because remember that Thetis is essentially the radio, not the box with Apache Labs written on the side. The box is merely some of the RF hardware. And the PC running Thetis must be local to the ANAN. You cannot run Thetis over the internet.
While the amp interface is simple, again as described above in this very thread, remotely operating Thetis is not anywhere near as easy as with a Flex. Flex is the king of remote op's. Anything you do with Thetis will be a lash up of some sort.
K7ONY
Post by K7ONY »
Very nice info..... took a second to beat it into my little pee brain, but I think I have it... at least for the local setup. Now I have to figure out how to set up cat control out of the computer. I think I'm going to have to use a USB to serial adapter. Great learning opportunity.
Since I am not using Thetis , instead I followed the manual and loaded OpenHPSDR PowerSDR mRX. Also at the risk of getting off topic, Does Thetis have any different functionality over the OpenHPSDR? Is there another software tool to use instead of these two or a third party to use in addition?
I do use Team viewer as one of my remote tools for any maintenance work... i/e rebooting the server, making sure the remote client is working correctly, swinging the beam, changing power on the amp... a few more. The radio is not directly controlled by the teamviewer at all.
K7ONY wrote:Very nice info..... took a second to beat it into my little pee brain, but I think I have it... at least for the local setup. Now I have to figure out how to set up cat control out of the computer. I think I'm going to have to use a USB to serial adapter. Great learning opportunity.
Yes, way off topic ;)
I suggest you start a new topic asking about the differences between Thetis and PowerSDR mRX in the Thetis sub-forum: viewforum.php?f=9
And another topic, if you have more questions about remote operation, in the remote operation sub-forum: viewforum.php?f=24
SM3PZG
Post by SM3PZG »
Hi guys,
I am trying to connect Andromeda to SPE EXPERT 1.3K-FA. I followed the instructions in previous post and made a cable with:
DE9:DA15
5 4 Ground
2 1 Rx
3 9 Tx
Have installed a USB to RS232 adapter. It shows up in device manger as COM8. I have verified functionality by connecting to another rig. Have set Thetis to Id: as TS-2000. CAT2 is set to COM8 9600 N81. Expert is set to Kenwood 9600. Connecting the cable I made to the RS232 adapter nothing happens. Just feels like Thetis is not communicating with COM8
Just had the Andromeda a few days and a lot to learn. Would appreciate any suggestions on how to get the RS232 port running.
73/Sam SM3PZG
Sam,
It seems some people are buying USB or other cables that end up with a DCE pinout instead of the traditional DTE pinout associated with PCs.
If this doesn't work:
DE9 DB15
Pin 5 Pin 4 Ground
Pin 2 Pin 1 TX 232
Pin 3 Pin 9 RX 232
Then simply try this:
DE9 DB15
Pin 5 Pin 4 Ground
Pin 2 Pin 9 TX 232
Pin 3 Pin 1 RX 232
One of those two should work.
SM3PZG
Post by SM3PZG »
Thanks for the quick reply Scott,
I missed Andrews post with
PC DE9 : SPE DA15
GND 5 : 4 GND
RX 2 : 9 TX
TX 3 : 1 RX
7&8 looped RTS/CTS
I tried that and it worked!
73/Sam
N4XD
Post by N4XD »
I just acquired a spe amp. Even after reading the string for this topic I am confused.
The spe amp only listens. Doesn't transmit any data back to the radio. So should only need to monitor the RS232 TX line. So the pinout, I think, should be.
I installed a pcie card with real rs232 ports.
PC DB9 Amp DB15
pin 3 (rs232 tx) pin 1
pin 5 (ground) pin 4
Wonder if someone with this same set up can confirm for me that this is what they are using? I of course see the set up Sam is using but again, the amp is just a listener so I'm confused why the other wires are needed.
Ron
N4XD
Most equipment, and software, polls for info. I believe this is also true for SPE amps.
N4XD
Post by N4XD »
I made up the cable as outlined in the spe manual for the Kenwood or Elecraft radios.
Then, on a whim, decided to see if DX Labs Commander might communicate with the amp. Indeed, it did! At least now know the cable is good.
Now with Thetis. Still no joy.
Turns out that Thetis requires a lower comm port number. I had defined mine as comm 23. Renumbered to comm 11, rebooted computer, turned on comm 11 in Thetis ( setup/ serial/ network ... tab). I defined cat2 control as comm11. Now the amp follows band changes in Thetis.
I can't understand why Thetis won't work with higher comm port numbers. I thought this problem was something from the early 2000s. Obviously not.
Hope this helps someone avoid the frustration I've had. I bet, had I started with comm 11 I'd have had this going first try.
Ron N4XD
N4XD wrote:Turns out that Thetis requires a lower comm port number. I had defined mine as comm 23. Renumbered to comm 11, rebooted computer, turned on comm 11 in Thetis ( setup/ serial/ network ... tab). I defined cat2 control as comm11. Now the amp follows band changes in Thetis.
You need to qualify that statement. Thetis won't work with higher comm port numbers on your system. Thetis works absolutely fine here with port numbers in the twenties and thirties.
I do not believe this is a Thetis problem.
At any rate, most people number their real hardware ports in the single digit range. It's normally the virtual serial ports that exhibit this problem. It's not a problem for VSPE and Thetis on my system. Nor is it a problem for Thetis and Moxa device server ports on my system.
N4XD
Post by N4XD »
OK, I qualify my statement. AND for this specific application. Of course difficult to know it works on other's systems since, well, I have only this one :)
Ron
m1tzr
Post by m1tzr »
Very helpful
DE9 DB15
Pin 5 Pin 4 Ground
Pin 2 Pin 9 TX 232
Pin 3 Pin 1 RX 232
Is what has worked for my :-)
Michael
Post by Michael »
I soon (hopefully) will receive a ANAN G2 which I would like to hook it up directly to my SPE Expert 1k3 using one of the G2 USB ports and a USB to serial adapter with the wiring as outlined in the SPE manual. Thetis will be used in a different room on a Windows computer in the same network. As the G2 does not support AGC, Thetis will be used to control drive level avoiding overdriving the amp. CAT control of the SPE Amp (at least following band/frequency change) will be established with the Thetis CAT control using virtual ports.
I was informed that the current version of Thetis is not supporting the control of the USB ports on the G2 via the network? Is this correct? And if so, has anybody tried to use a Linux tool on the internal Pi computer of the G2 acting as a server for USB over ethernet? It would be easy to install a client on the Windows computer providing a virtual usb port which then could be used by Thesis (using the Kenwood CAT format).
Has anybody experience with a similar setup?
73, Michael
Michael wrote: I was informed that the current version of Thetis is not supporting the control of the USB ports on the G2 via the network? Is this correct?
AFAIK that is correct.
I don't know anyone who has done this with a G2 specifically, but it's a problem that has been solved a million times over. There are at least a dozen ways to do this using various bits of software on the Linux and Windows sides. Here is merely one example. Since you have complete and total access to the Pi in the G2, this should be a straightforward operation to install and configure.
Another alternative would be to buy or build a hardware serial device server. The Moxa Nport devices are excellent.
Michael
Post by Michael »
Great - Thanks! I will try as soon as the G2 has arrived.
Best regards,
Michael
Michael
Post by Michael »
Dear all,
I approached SPE in Rome today with a few questions one related to Digital Predistortion using the Expert 1k3. You may find this information useful, too.
The Expert 1k3 does not have a dedicated RF sample output for the pure signal feedback and as I would like to avoid using couplers on each antenna port in use, Marco from SPE provided me with an easy-to-implement modification of the SPE Expert 1K3. It only requires 2 resistors, some coax cable and a BNC plug. Here what he suggested:
The SPE 1.5K-FA model is already equipped with a predistortion output.
The signal is sampled from the SWR meter board with a 60 dB attenuation
and brought to the back panel via an SMA connector.
You could implement the same setup for your 1.3K-FA. The SWR meter board
is mounted vertically on the filter board. Here's what you need to do:
- Connect an 820 Ohm, 1/2 W resistor to the anode of D1.
- Then, connect the resistor to a 56 Ohm resistor, which has to be grounded.
- The -60 dB signal can be taken from the 56 Ohm resistor.
D1 ---/\/\/\/-----/\/\/\/---- GND
820 | 56
<-- -60dB --- GND
Thanks, Marco!!!
Michael
Post by Michael »
Michael wrote:Great - Thanks! I will try as soon as the G2 has arrived.
Best regards,
Michael
Short update as I received the ANAN G2 three days ago (I wrote an update yesterday night but apparently it was lost when uploading).
In short:
USB over IP (USBIP - I used the VirtualHere software which makes the setup very easy) works flawless also via WLAN. I can fully control the SPE 1k3 amp with the Raspberry Pi withing the G2 using the 2 USB ports. The VirtualHere server on the Pi connect one USB via a RS232 adapter to the 15pin CAT input on the amp. The second USB is connected to the USB input of the amp for the TERM controlling software. The VirtualHere client on the Win11 PC assigns two local virtual Com ports for the remote USB ports which then can be used for the Thetis CAT control and the TERM software (it will find the amp automatically). The SPE amp need to be set to FLEX cat control which uses the same protocol format as Kenwood but allows to programme the drive level for LOW/MID/MAX power for each band (see SPE manual for details). Using VirtualHere outside the local network requires one additional small change by providing the IP Address of the Pi.
This was easy but I am still fighting with the settings of the AUDIO and driver for the sound card but I guess this should be posted into another thread.
73, Michael, DF2RQ
P.S. Forgot to mention that you also need to connect the PTT outlet to the amp but thsi is obvious
Michael
Post by Michael »
Not sure it is the right thread but I assume that the delay settings wirhin Thetis strongly depends on the hardware in use.
Does anybody also have the G2 with a SPE Amp and if yes, have you found the perfect delay settings?
Using CW I realized some missing dits and dahs from the Winkeyer after transmitting for a couple of minutes. I am not sure it is only the G2 internal sidetone or if it is being sent out like this (the sidetone provided by the Winkeyer is OK). This is why I assume it is not RF related but rather an issue of wrong (or not optimized) delay settings.
Any hints are welcome.
73,Michael, DF2RQ
