I am offering an up-front apology to the Moderator as I have been dubbed the "King" of being able to cram totally unrelated things into one subject so here I go again and I may have fallen prey to the same mistake
I have been pulling my hair out over the sudden decrease in noise-floor as everyone can attest to, to the point of suspecting that I had the wrong antenna connected to the radio. Regardless of antenna and band with 4 different antennas and independent coaxial runs from the shack to the feed-point of those antennas, I have observed this issue during several days. I won't buy that the coax connectors and coaxial runs on all 4 antennas are sketchy and the culprit. Perhaps, if what I had been observing happened on only 1 or 2 bands, perhaps, but not all 4 bands. Also, I took the amp out of the circuit, connecting the radio directly to antennas, using ANT 2 port, and RX 2, swapped out the coaxial jumper that I use to connect the radio to antennas (or amp). It seemed like the receiver noise-floor was fairly steady when antenna was on ANT 2 port (2 hours of monitoring), but I am not sure how "conclusive" that is.
Lately, I am seeing problems during transmit as well, not merely receive. I was on 40 last night, rag-chewing for about 40 minutes, talking to a local fellow here in Texas. While listening to him, I noticed that the noise-floor went really low (on 40, the noise-floor is really high, evenings) and he was going to hand it over to me. From the first syllables of my talk, Pure Signal appeared to go completely out-of-whack and it wasn't correcting at all (RED flashing, and BLUE etc., finally GREEN) for around 10 s, then I saw correcting for a little while and, then the sequence repeated again. First thing that came to my mind was a defective T/R relay in the radio and this is something that others have suggested. As I had posted previously, W5WC wasn't able to reproduce what I had been observing. He did mention that he had not conducted longer term testing while transmitting. Logical as I had not observed any issues on the transmit side of things when I shipped the radio.
Now, I started looking at the Ethernet CAT8 cables plugged into the "dumb" T switch and noticed that the cable from the switch to the PC looked a little suspect. It seemed like it was somehow "askew" and when I unplugged it (yes, I didn't forget that there is a "tab" on the end that you are supposed to use to help unplug the thing) it was much more difficult than with the 3 other connectors.
Could the above have played into the intermittent issues I have been observing? I will continue running tests, to see if did play into this
