Page 2 of 2
Re: So Disappointed But I Rolled it Back. 7000 MK III To Protocol 1
Posted: Mon Jan 29, 2024 1:34 am
Chiron wrote: I've noticed a frequency offset when using protocol 2 with a 7000DLE MK3. It is around -160Hz. When using protocol 1, the frequency is correct (within several Hz). I asume that with only changing between protocol 1 and 2 firmware, the frequency should be identical.
Do you also have the frequency offset only with protocol 2?
See this topic: viewtopic.php?f=9&t=4969
Posted: Tue Feb 06, 2024 3:58 pm
by StefanoAlvaro
Chiron wrote:
StefanoAlvaro wrote:
n1gp wrote:Hi Vin,
Yes, but I had never given it any importance. I just installed the new fw 2.2.2. vers.A and tried to keep it in TX for a long time, at the moment it seems to work!!!
I'm waiting to claim victory, I want to test it well and call CQ for at least an hour/two, but something has definitely improved. I always thought this couldn't depend on the temperature and I wasn't wrong.
Posted: Tue Mar 12, 2024 6:44 pm
by KD1GA
I'm officially claiming victory:). Since I updated to the new firmware to fix the RF on the RX port and also went to CM ASIO Protocol 2 has worked perfectly for two months. Maybe that little bit of RF from the RX port was what was messing with the firmware timings. Vin KD1GA
Posted: Tue Mar 12, 2024 7:04 pm
by n2gq
KD1GA wrote:I'm officially claiming victory:). Since I updated to the new firmware to fix the RF on the RX port and also went to CM ASIO Protocol 2 has worked perfectly for two months. Maybe that little bit of RF was messing with the firmware timings. Vin KD1GA
Did you terminate the open ports as well?
Posted: Wed Mar 13, 2024 8:35 pm
by KD1GA
Yes, port shunting was one of the first things I did when i first suspected RF and that didn't solve the issues. Thanks for your suggestion a while back. I apologize for not confirming it was already done back months ago when you originally suggested it.
Posted: Thu Mar 14, 2024 1:49 pm
by n2gq
KD1GA wrote:Yes, port shunting was one of the first things I did when i first suspected RF and that didn't solve the issues. Thanks for your suggestion a while back. I apologize for not confirming it was already done back months ago when you originally suggested it.
Yes my friend told me as well as another gentleman one night I sounded like Darth Vader. Then another person came on frequency and told me I was bothering him a bit above. I was leaking into 10mhz port, of course during high power tx .
