Page 2 of 4
Re: Thetis v2.10.3.5 Pre-Release
Posted: Thu Dec 14, 2023 1:35 pm
by Tony EI7BMB
Ah, thanks for that Richie
Tony EI7BMB wrote:Anyone notice that NB stays on during TX ?
It turns off during TX only if DUP is on
Posted: Thu Dec 14, 2023 6:58 pm
by WR1S
I am running Thetis v2.10.3.5 Pre-Release 3. I have it configured to prevent Tx on non-Ham freqs in the US. (Extended not checked in Setup). It works as expected with one minor thing.
If I Tx with the Thetis MOX button or the spacebar, I get the pop warning window, I close the window and Thetis continues.
If I Tx using my CMD-PL1 midi controller mapped key, I get the popup warning window, I close the window, and Thetis powers off. The Thetis power button goes off. I have to press power again in Thetis to continue.
It's not a big deal but it seemed inconsistent to me.
Thanks for the great work you do for all of us!
Rick, W1RHS
Posted: Thu Dec 14, 2023 8:45 pm
by f6ctt
f6ctt wrote:Hello
With my Anan 200 D, the VAC1 doesn't work : no audio
back to the version 2.10.3.4 : audio is OK
73 Joseph F6CTT
Hello again
If I uninstall version 2.10.3.4 and install today's version 2.10.3.5 prerelease-4, VAC1 does not work (no audio in the headset).
After doing a new installation of today's prerelease version-4 (I deleted the OpenHPSDR directory to do so), VAC1 works again.
73 Joseph
Posted: Thu Dec 14, 2023 9:36 pm
f6ctt wrote:Hello again
73 Joseph
Where was there any notice of a new 2.10.3.5 pre-release 4 posted?
Posted: Thu Dec 14, 2023 9:46 pm
K1LSB wrote:Where was there any notice of a new 2.10.3.5 pre-release 4 posted?
there wasn't one this time Mark
Posted: Thu Dec 14, 2023 10:21 pm
W1RHS wrote: If I Tx using my CMD-PL1 midi controller mapped key, I get the popup warning window, I close the window, and Thetis powers off. The Thetis power button goes off. I have to press power again in Thetis to continue.
The code turns off the radio if a cat based ptt/mox fails (midi uses cat functions/calls). It fails due to being out of band and then it just powers off. I checked back to March 2017 and the code is there, and like 99% of the strange things that go on in the spaghetti, there are no comments as to why.
Posted: Thu Dec 14, 2023 11:14 pm
ramdor wrote: The code turns off the radio if a cat based ptt/mox fails (midi uses cat functions/calls). It fails due to being out of band and then it just powers off. I checked back to March 2017 and the code is there, and like 99% of the strange things that go on in the spaghetti, there are no comments as to why.
This has always seemed to be a rather overly draconian response to an attempt to transmit out of band. It would be vastly preferable if the software merely refused to TX. A pop-up message isn't even required.
Posted: Thu Dec 14, 2023 11:21 pm
by w9mdb
Seems to me the problem might be that you really don't know if the PTT worked.
If the PTT was never sent that would fix that problem though you'd still want some sort of warning...otherwise people are wondering why PTT doesn't work. A temporary popup of "Frequency X.XXMHz is out of band -- PTT aborted" should do.
Still same behavior though if PTT is sent and fails for any reason you don't know the state of the rig so power off is the safety position.
Posted: Fri Dec 15, 2023 11:44 am
by Mike_N1JEZ
I must be missing something, but I can't find the link for the download for pre-release 4... other than https://github.com/ramdor/Thetis/releas ... -release-4
Posted: Fri Dec 15, 2023 11:56 am
by NC3Z
Mike_N1JEZ wrote:I must be missing something, but I can't find the link for the download for pre-release 4.
Have you scrolled to the bottom of the page?
Screenshot 2023-12-15 065658.jpg (126.26 KiB) Viewed 100089 times
Posted: Fri Dec 15, 2023 12:02 pm
by Mike_N1JEZ
Boy do I feel foolish. I could have sworn I scrolled down to the bottom....
Tnx, Mike
Posted: Fri Dec 15, 2023 12:07 pm
by Tony EI7BMB
Took me a while too Mike :)
Mike_N1JEZ wrote:Boy do I feel foolish. I could have sworn I scrolled down to the bottom....
Tnx, Mike
Posted: Fri Dec 15, 2023 2:32 pm
by n2gq
When using panafall and I try to expand the waterfall all the way up Thetis exits. Also happened once when scrolling the frequency bar on top of spectrum display.
Radio is 7000del mkIII
Firmware 2.1.12
Running W11 7800xt video card latest amd drivers.
Video below.
https://youtu.be/cuChn1B5Rno
Posted: Fri Dec 15, 2023 2:45 pm
by oe3ide
n2gq wrote:When using panafall and I try to expand the waterfall all the way up Thetis exits. Also happened once when scrolling the frequency bar on top of spectrum display.
Firmware 2.1.12
Video below.
video unavailble (I guess private)
Posted: Fri Dec 15, 2023 5:45 pm
by n2gq
Firmware 2.1.12
Video below.
Video should be available now.
Posted: Fri Dec 15, 2023 6:14 pm
can you send me this zip. My email is over on qrz. Cheers.
Posted: Fri Dec 15, 2023 8:15 pm
by n2gq
Okay on it's way.
Posted: Sat Dec 16, 2023 3:50 am
by vk1hx
Posted: Sat Dec 16, 2023 10:49 am
n2gq wrote:Okay on it's way.
Sadly nothing of relevance in the errorlog.txt file. I ran up your db and spent about 5 mins slamming the splitter bar from top to bottom, dragging the splitter bar, and no issue.
If you can get it to repeatedly happen on demand, try closing down all other programs and clearing out everything from the the system tray icons.
Posted: Sat Dec 16, 2023 12:59 pm
by w9mdb
It may matter how the monitors are setup assuming there are at least two monitors (which I suspect there is).
Mine are "extended" with the #1 screen top and #2 on the bottom and I can't duplicate this problem.
But if you put #1 on the bottom and #2 on the top the offset numbers are negative -- perhaps that's the problem?
Posted: Sat Dec 16, 2023 2:19 pm
by n2gq
Okay will try clearing programs from the tray. Will let you know how that turns out.
Posted: Sat Dec 16, 2023 3:59 pm
by n2gq
Okay I cleared as many as I could programs from system tray but same thing was happening. I then reduced display resolution down to 1080p from 2160 and I could not trigger the exit of thetis. I dragged multiple times and nothing happens. Will continue checking. Also exits at 1440 resolution.
Posted: Sat Dec 16, 2023 4:50 pm
by n2gq
At 2160 or 4k resolution and the recommended scale of 150% thetis exits if I drag up the waterfall. But if I move the scale to 175 and above it does not exit.
Also got this window one time. Picture attached.
Thetis crash20231216_111028.jpg (689.27 KiB) Viewed 99460 times
Posted: Sat Dec 16, 2023 4:54 pm
I'm running 4K resolution and cannot duplicate this problem.
Edited to add: also running 150% scaling.
I know this is a somewhat trite suggestion, but have you tried updating your video drivers?
Posted: Sat Dec 16, 2023 7:29 pm
by n2gq
w-u-2-o wrote:I'm running 4K resolution and cannot duplicate this problem.
Yes, just the day before I updated the Radeon drivers.
Posted: Sat Dec 16, 2023 8:30 pm
by n2gq
Okay I am using a display port cable to my monitor. And when I use an HDMI cable it does not occur.
Talked a bit soon, it still occurs but takes a bit longer.
Posted: Sun Dec 17, 2023 3:31 pm
n2gq wrote:Yes, just the day before I updated the Radeon drivers.
was it an issue before you updated them?
Posted: Sun Dec 17, 2023 6:23 pm
by n2gq
Don't know but going back one to see if it was an issue. Get back to you.
Posted: Sun Dec 17, 2023 6:43 pm
by n2gq
Not sure as I don't use the waterfall in full screen all the time .
I went back as far as 2.10.0 and it did the same thing.
Going to try a different driver for gpu.
Posted: Mon Dec 18, 2023 10:15 am
updated to pre-release-5 and hopefully the last pre-release
