Page 13 of 20
Re: 2.6.9
Posted: Tue Dec 17, 2019 4:11 pm
by np2g
Hello
Using (b4) When selecting (CTUNE) and then running the GUI in Collapse . I find no way to Turn CTUNE function off while in this collapse mode .
I see It can be turned off by going back to the Expanded display . Is this how it is suppose to work?
Ed NP2G
Re: 2.6.9
Posted: Tue Dec 17, 2019 4:26 pm
by np2g
On collapsed
Looks like part of the 4 is missing ??
Re: 2.6.9
Posted: Tue Dec 17, 2019 5:19 pm
w-u-2-o wrote:Is the "Wheel Tunes Outside Spectral" problem fixed in b4?
Cheers!
not sure there was anything to fix Scott. See : https://apache-labs.com/community/viewt ... 2b38#p9435
It doesn't do what you think it does.
While I now have no doubt it does not do what I think it does :D that link just takes me back to this exact spot in this exact topic. Please pardon a rare bout of cluelessness on my part: what does that option do, exactly? I feel pretty stupid right now because I remember you and I discussing how tuning should work at great length :oops:
Cheers!
Re: 2.6.9
Posted: Tue Dec 17, 2019 5:37 pm
by NC3Z
w-u-2-o wrote:Please pardon a rare bout of cluelessness on my part
You are holding it wrong!
Re: 2.6.9
Posted: Tue Dec 17, 2019 5:52 pm
It just prevents you from using mousewheel to tune when the mouse pointer is not over the spectral display. ie, mouse wheel works outside spectral area if enabled. It was put in to prevent accidental scrolling of frequency if you missed some other slider slightly, such as drive, agc gain etc etc etc. It is explained in post above showing blue/red overlay image. No idea why that link didnt take you to the post. I will link again https://apache-labs.com/community/viewt ... =330#p9435
Anyhoo...when CTUN is enabled...
So when you drag the passband and you are massively zoomed in, such that passband cant not be entirely shown, the spectrum scrolls to follow the passband/filter with zero pos in the middle.
At all other times, the passband will move, until it gets close to an edge, at which point the spectrum scrolls. You can think of it when massively zoomed in, that it is already near the edge so the spectrum will scroll.
The other case is if you drag the spectrum using the top strip, the passband will be moved if is about to go off the edge of the IF sample area, essentially preventing it from leaving the IF.
From memory, the only way the passband will leave the view is if you use the top scroll or pan when in CTUN mode.
Re: 2.6.9
Posted: Tue Dec 17, 2019 5:57 pm
np2g wrote:On collapsed2snap.PNG1snap.PNG
mute display text box/label has been moved down there by the andromeda code, and the background is not transparent. It needs a rework/reposition, but as I will be dumping compressed view in a couple of weeks (more like months), not worth worrying about at this stage.
Re: 2.6.9
Posted: Tue Dec 17, 2019 6:40 pm
by np2g
Hello On the Missing part of #4 That was not a complaint just a observation.
You are working your butt off Thank You.
Personally I like to see it as is it's looking like OM Great amp hi
Ed NP2G
Re: 2.6.9
Posted: Wed Dec 18, 2019 2:18 am
ramdor wrote:Hi Scott,
I am such a dolt! I can't believe I didn't remember that. That really was a stupid question. Very embarrassed I am! :oops:
CTUN behavior I understood :)
Re: 2.6.9
Posted: Wed Dec 18, 2019 12:49 pm
UPDATE
Note: waterfall update interval code changed, you will probably need to change delay setting in Setup>Display>RX1/rx2. It is now frame rate based. It did not make sense to perform it after some arbitrary interval, because that interval may or may not have aligned with a redraw of the frame. Consequently inconsistent jitters could be observed in the waterfall. You now have the option to change the frame interval which defines when a new line is added to the wf. The ms number shown is how often the line will be added.
Last update before Christmas unless something is broken (I said that last time). Code will go off to Doug in a couple of days if nothing serious found.
73, Richie.
(11/19/19) b5 + b5_1
-change: waterfall draw delay removed, now entirely based off FPS and a frame interval
-fix: linAuto now displays in colour in DX engine, min/max bug
-add: duration of smeter signal history
b5_1 fixed issue with time display when hovering mouse over waterfall
Re: 2.6.9
Posted: Wed Dec 18, 2019 1:33 pm
by Tony EI7BMB
Thanks so much Richie happy Xmas
Re: 2.6.9
Posted: Wed Dec 18, 2019 5:56 pm
by DO2ZA Erwin
DO2ZA Erwin wrote:Hi all and Ritchie,
at first 2.6.9 b2 is running perfekt here, many thanks !!
Right Click on CPU in Status-Bar ?? No funktion here??
Sometimes I have a problem to save my Setting in the Database, here it is on DSP - Options, the Filter-Type. Sometimes it is saved, some
time not?? (B1 Version).
73 Erwin
cpu status bar change as not yet been released. Saving issues, probably related to TX profile, save the TX profile and should be ok?
yes, TX-Profile saving is working fine, but i mean that will not save the Filter-Type???
I have the Database manuell edit, now it works again.
73 Erwin
EDIT: Tested: Saving TX-Profile saves also the Filter-Type from DSP-Options. If I use Apply and OK on the Setup-Form
it saved NOT the DSP-Filter-Type !!
73 Erwin
Re: 2.6.9 QSK Oddity?
Posted: Thu Dec 19, 2019 6:42 am
by KA1GXR
Greetings all:
Using Thetis 2.69 B1 or B5 on my 200D while testing for RF leaking into Ant 2 while Tx assigned to Ant 1 Found the following:
If QSK is turned on Tx power goes to whichever RX antenna is selected 1,2, or 3 even with Ant 1 checked as TX and check boxes
under ANT 2 and 3 for do not transmit on those antennas. I also See the previously reported leakage during non QSK transmit to
Ant 2, About -10 db to plus 5 db during random keying spikes in CW mode. Lengthening Keyup delays does not stop the spike. Not
looking for solution to that here. See Similiar spike on my 8000 DLE also.
Only curious if tx during QSK is normal. Tested on 2nd desktop PC also with same results so I do not suspect corrupted database.
Tom
KA1GXR
Re: 2.6.9
Posted: Thu Dec 19, 2019 11:19 am
by W2SDR
I have been noticing with the last few releases that when I'm on AM for a while and use the space bar for the PTT for a QSO, when I switch to SSB and turn VOX on the VOX does not work. The only way I can get Vox to start working agn is to restart the software. Then all is well. I am using VAC with a USB mic pre for my mic audio.
Frank, W2SDR
Re: 2.6.9
Posted: Thu Dec 19, 2019 11:47 am
W2SDR wrote:I have been noticing with the last few releases that when I'm on AM for a while and use the space bar for the PTT for a QSO, when I switch to SSB and turn VOX on the VOX does not work. The only way I can get Vox to start working agn is to restart the software. Then all is well. I am using VAC with a USB mic pre for my mic audio.
Frank, W2SDR
I wonder if it is that when changing mode from AM to SSB, it may also change to another TX profile, that ssb tx profile not enabling the vac?
Re: 2.6.9
Posted: Thu Dec 19, 2019 1:35 pm
by K9RX
Tom, KA1GXR, not sure if this is the same thing but it sounds similar at least in part ... check out my post and the thread here:
https://apache-labs.com/community/viewt ... 8668#p8668
this is regarding an issue where there is RF present that causes preamps to blow and false "HIGH SWR" to be seen ...
Re: 2.6.9
Posted: Thu Dec 19, 2019 3:14 pm
by np2g
Hello
I am presently now utilizing VAC for the audio input .
And when I have used this function (OFF DELAY PTT) in HPSDR this provided the ability to add time to the off command while using PTT
thus compensating for the latency .
Thetis does not have this function.
It would be nice to re establish this ability in Thetis.
ED
NP2G
Re: 2.6.9
Posted: Thu Dec 19, 2019 8:53 pm
by wa1oxt
Request....
Is it possible to have a vertical gain adjustment included within the "Scope" and "Scope2" feature on the main gui ?
Also , does anyone have a clue how to get the playback feature working when in VAC ?
tnx
garyradio / wa1oxt
Re: 2.6.9
Posted: Thu Dec 19, 2019 9:47 pm
by VA2EY
trick
For recording, with output level identical to the input, RX1AF: must be 100. In this way no need to adjust TX gain (Wave Menu) and the AGC Gain can also reduce the recording level ...
Michel
Re: 2.6.9
Posted: Fri Dec 20, 2019 1:11 am
by wa1oxt
Ok, I 'll figure out the issue with the Rec / Playback.
More interesting is that Playback does't work on start-up
ie: try this... Bring up Thetis , push the Playback button...nothing happens !
If you select MOX and then select Playback..nothing happens with Playback
I had to check to see if indeed there was a .wav file in the directory.
To solve the problem , snip a new recording off the air ,then all is wonderful.
Well , wonderful as far as the buttons working.
Transmitting the file over the air is still a problem using VAC.
oxt
Re: 2.6.9
Posted: Fri Dec 20, 2019 1:51 am
by KA1GXR
K9RX wrote:Tom, KA1GXR, not sure if this is the same thing but it sounds similar at least in part ... check out my post and the thread here:
Gary I saw your post some time back and even contacted Doug about it. Testing on that issue I found a different problem using the Thetis QSK feature. I only use CW for PA calibration and tuning normally. Whatever power is set in the 200D in this case (not using my amp for these tests) comes out Antenna 2 port when I select Antenna 1 as transmit port and check boxes at the bottom of antenna filters page for NO TX on ports 2 and 3 . That works Ok when QSK is not selected other than the low level leakage and nasty spike up toabout +5DB I capture on my spectrum analyzer. I posted elswhere (diversity area) to someone who uses some sort of optocoupler switch on the rx line I think. Waiting for more info on that also as a partial fix.
Got expensive blowing Magnetic rx loop amps until I figured out why. Using RX2 (ADC2) Has very little leakage and no spikes yet on 200D and 8000dle.
Tom/KA1GXR
Re: 2.6.9 QSK Oddity? Attention Richie*****
Posted: Fri Dec 20, 2019 1:56 am
by KA1GXR
KA1GXR wrote:Greetings all:
Tom
KA1GXR
I was concerned this QRX problem may be in Thetis 2.69 etc. Do not know when it became available but version 2.69 b1 and b5 do it.
Tom
Re: 2.6.9
Posted: Fri Dec 20, 2019 10:49 am
by DL8LAQ
just a note for your wishlist:
It would be nice to get rid of the yellow TX filter lines in the spectrum display when using DIGU / DIGL or FM. A TX FL button like in all other phone modes would be nice.
Re: 2.6.9
Posted: Fri Dec 20, 2019 1:44 pm
UPDATE
Please try: https://www.dropbox.com/s/s0b5w7w3qt1yj ... 3.zip?dl=0
Contains changes to the playback of recordings. Not 100% this is the correct solution, but perhaps Bryan can check it when source gets back to Doug. VAC is put into 'bypass' state during the playback.
73 Richie.
(11/19/19) b5_2
-add: a PTT delay can be inserted before entering TX state (taken from PowerSdr. Requested by np2g. Default 0ms)
-change: can now play a recording. Bypass vox is used for the duration. There could be issues with this, please give findings. Changed for the wave file controls playback as well
Re: 2.6.9
Posted: Fri Dec 20, 2019 2:09 pm
by np2g
Thank You for the PTT off delay
Merry Christmas Ho HO HO
Ed Baker
Re: 2.6.9
Posted: Fri Dec 20, 2019 2:22 pm
by VA2EY
Hi Richie
TX Gain (dB) in Wave menu no longer works with version 2.6.9 b5_2
Michel
Re: 2.6.9
Posted: Fri Dec 20, 2019 2:26 pm
VA2EY wrote:Hi Richie
Michel
Hi Michel,
I noticed that here as well when the vac is in bypass mode, which is why I put the caveat around the release (may not be the correct solution)
Did it work before? please explain what settings you used to play wave recordings via that wave form. Are you using vac or direct connection to radio for audio etc etc?
Cheers Richie.
Re: 2.6.9
Posted: Fri Dec 20, 2019 2:40 pm
by VA2EY
I have not used VAC. Always in direct connection, and worked with all previous versions
but works using VAC
Michel
Re: 2.6.9
Posted: Fri Dec 20, 2019 2:42 pm
Hi Michel, Just did a quick test here, after initially thinking it did nothing it does seem to be ok? Perhaps there is a setup/setting difference between us somewhere?
See vid :
Re: 2.6.9
Posted: Fri Dec 20, 2019 2:46 pm
VA2EY wrote:I have not used VAC. Always in direct connection, and worked with all previous versions
Michel
ah ok, I will have to look into it again then in that case, or ask Bryan to take a look
Re: 2.6.9
Posted: Fri Dec 20, 2019 2:51 pm
by VA2EY
Works with VAC only
Michel
