Page 3 of 4
Re: Thetis v2.10.3.5 Pre-Release
Posted: Tue Dec 19, 2023 5:02 am
by Trucker
Installed pre-release 5. So far after running for several hours, it has been rock stable. No overflows and underflows of any kind. I have to look close just to be sure the numbers are changing! Everything I have tried has worked smoothly.
Thanks Ritchie Thetis just gets better and better.
Posted: Thu Dec 21, 2023 10:23 am
by Tony EI7BMB
Installed pre release 5 and noticed that if you hold the mouse over CM indicator logo the pop up info message flashes on/off. Anyone else seeing this ? CAT TCP enabled message next to it works ok.
Posted: Thu Dec 21, 2023 10:50 am
by W4WMT
Hi Tony,
Not seeing the blinking cmASIO icon, looks steady here on pre-5.
My CAT/TCI icon is OFF however.
Bryan
Posted: Thu Dec 21, 2023 10:57 am
Tony EI7BMB wrote:Installed pre release 5 and noticed that if you hold the mouse over CM indicator logo the pop up info message flashes on/off. Anyone else seeing this ? CAT TCP enabled message next to it works ok.
this happens with some/all status bar tool tip text afaik, some external program perhaps interacting with it, or some other reason. Not looked into it but I am aware. The toot tip text is only set once at startup for the cmASIO icon, and not/shown hidden by any code, so it hiding/showing is some failing of windows/statusbar/the universe/simulation ;)
Posted: Thu Dec 21, 2023 11:09 am
seems to be caused by mouse pointer entering the tool tip, causing mouse leave event on the icon, closing the tooltip, and then it cycles. Just have to live with it for now as I don't really have plans to re-write Microsoft's tool tip system :D This can also be seen if you move/expand the console window so the status bar is very close/slightly behind the desktop TaskBar.
Posted: Thu Dec 21, 2023 11:11 am
by W4WMT
Just turn off CAT/TCI and it works FB :-)
Posted: Thu Dec 21, 2023 11:29 am
W4WMT wrote:Just turn off CAT/TCI and it works FB :-)
if only :D
Posted: Thu Dec 21, 2023 11:43 am
by W4WMT
Can't duplicate your bug.
Works fine here OM :-)
Posted: Thu Dec 21, 2023 11:48 am
W4WMT wrote:Can't duplicate your bug.
not my bug :lol:
Posted: Thu Dec 21, 2023 12:13 pm
by w9ac
It happened to me once since installing pre-release 5. Flashing occurs when hovering the mouse over TCI, CAT/TCP, or CM. Restarting Thetis stopped the flashing.
Haven't seen it occur since.
Posted: Thu Dec 21, 2023 12:50 pm
by W9EZ
I also have the flashing. Began on prerelease 4 when there was only the cmASIO icon on the left. Now all 3 icons work solid the first time and then flash after that.
W9EZ
Posted: Thu Dec 21, 2023 12:57 pm
by Tony EI7BMB
Thanks guys. As Richie says no big deal right now.
Posted: Thu Dec 21, 2023 1:01 pm
W9EZ wrote:I also have the flashing. Began on prerelease 4 when there was only the cmASIO icon on the left. Now all 3 icons work solid the first time and then flash after that.
W9EZ
they flash/cycle all the way back to v2.6.9 which was the first version that had the status bar, back in Jan 2020
Posted: Thu Dec 21, 2023 1:02 pm
by oe3ide
W9EZ
It's in Thetis since 2.6.9 and it's a microsoft bug. Case closed.
Posted: Thu Dec 21, 2023 1:04 pm
by W4WMT
I feel jealous because I can't make it flash here :-(
Posted: Thu Dec 21, 2023 3:37 pm
by Tony EI7BMB
Wanna swap ? :D
W4WMT wrote:I feel jealous because I can't make it flash here :-(
Posted: Thu Dec 21, 2023 5:08 pm
by W9EZ
Awesome.. THanks for the replies guys.. Not much of an issue I guess since I really hadn't noticed or tried to use them until the cmASio icon came about.
Posted: Fri Dec 22, 2023 1:15 am
by vk1hx
Posted: Fri Dec 22, 2023 10:11 am
by Tony EI7BMB
Thanks Phil
Re: Thetis v2.10.3.5 final release
Posted: Sun Dec 24, 2023 2:39 am
Thetis v2.10.3.5 final release is out over on github here : https://github.com/ramdor/Thetis/releases
Cheers for all the testing during the pre-release stages. Have a good Christmas folks. Cheers.
Overview video : https://youtu.be/aTvEznU2fY8?si=I9vJ1bnUVAPN0lEO
Posted: Sun Dec 24, 2023 2:59 am
by Joe
Thanks so much Richie,
I looked over all of your cleanup of so much of the massive lines of code! All I can say is you must be super fast at working lines of code. I couldn’t believe all of the work you did and with all of the great additions. Thanks again to all for the great updates and additions.
73’s
Posted: Sun Dec 24, 2023 8:08 am
by Tony EI7BMB
Thanks Richie, Happy XMas
Posted: Sun Dec 24, 2023 8:22 am
by ea3aqr
ramdor wrote:Thetis v2.10.3.5 final release is out over on github here : https://github.com/ramdor/Thetis/releases
First of all, thanks for the final release.
But unfortunately I have a problem with the 6m band.
After installing the final release, RX on 6m band is about 20db lower.
Going back to pre-release 5 cured the problem.
Posted: Sun Dec 24, 2023 8:41 am
by Tony EI7BMB
I am seeing the same here on 6m
After installing the final release RX on 6m band is about 20db lower.
Posted: Sun Dec 24, 2023 9:37 am
by liam
Thank you Richie for all your hard work
Happy Xmas and new year to you and your family
and to all on the forum
73s
liam
Posted: Sun Dec 24, 2023 10:40 am
Tony EI7BMB wrote:I am seeing the same here on 6m
UPDATE: fix to 6m lna. Same version number but titlebar will show 'u1'. Please test.
The spaceship would now be heading the wrong direction as a damn pesky ! was removed in the code clean.
Posted: Sun Dec 24, 2023 10:51 am
by Tony EI7BMB
U1 looks good here Richie , even have an E's opening on 6 to test with :-)
Posted: Sun Dec 24, 2023 10:57 am
Tony EI7BMB wrote:U1 looks good here Richie , even have an E's opening on 6 to test with :-)
Thanks for the quick test. Yeah there were thousands of lines of code junked in the project. I should have probably run a pre-release-6 :oops:
Posted: Sun Dec 24, 2023 11:00 am
by Tony EI7BMB
no worries, thanks again for all the work
Posted: Sun Dec 24, 2023 11:46 am
by vk1hx
