Re: Thetis Development Build 2.10.3.6 dev_5 available
Posted: Sun Jul 14, 2024 4:46 am
by vk1hx
Posted: Sun Jul 14, 2024 5:11 am
by vk1hx
Posted: Sun Jul 14, 2024 6:45 pm
Thanks for adding .bat support. I was simply going to change it to a .cmd file, but you beat me to it!
Your latest YT video popped up on my feed:
The current meter container paradigm is very "column oriented". Would there be any chance of allowing multiple columns in a single container? For instance, instead of 5 containers (including the empty spacer containers at either end) to get this, you could do it in a single container:
Cheers!
Posted: Sun Jul 14, 2024 7:38 pm
by kknickelson
Anyone seen this?
Started once OK then this.
Screenshot 2024-07-14 143458.png (81.01 KiB) Viewed 5455 times
Posted: Sun Jul 14, 2024 7:40 pm
try dev_6 wip_5. This should be resolved. Link in this post.....
Posted: Sun Jul 14, 2024 8:02 pm
@scott. There is quite a bit of reliance on the column orientation right now, and would take a fair bit of conversion to allow multi column. Also due to the vertical nature of the configuration setup list boxes they map directly to the positions in the view.
Never say never and all that but it is not something I have thought about too much. I would perhaps be interested in looking at coding up a different type of container, which is say a container of containers, and those sub containers could be positioned in any x/y grid layout.
Posted: Sun Jul 14, 2024 8:43 pm
dev_6 released now. I have just started a new thread for it. Head over there if you find anything Thanks all.
