Operating amplfiers in digital modes
Posted: Sun Apr 16, 2017 8:07 pm
Solid state linear amplifiers (such as the amplifiers in the RF chain of an ANAN-X transceiver or a solid state external linear amplifier) have RF output circuits that provide a fixed (designed in) RF load impedance to the output transistors*.
*In contrast to traditional tube amplifiers that incorporate a pi network with an adjustable loading capacitor.
When operating in a high duty cycle mode… such as JT65 or one of the other digital modes… reducing the RF output power level below the maximum rated RF output power level (by reducing the drive) does not typically reduce the power that will be dissipated by the output transistors. In fact, reducing the RF output level below the maximum rated RF output level will usually increase the power that will be dissipated by the output transistors.
This is because, with the transistors looking into a fixed RF impedance, the total electrical power consumed by the RF output stage is proportional to DC (average) value of the current being drawn by the transistors, but the RF output power is proportional to the square of the RF component of the output current being drawn by the transistors.
For example, with my Elecraft KXPA100 linear amplifier, running key down at full rated output on 20m:
RF output power = 100W
Average drain current = 11.3A
Drain voltage = 13.4V
Total electrical input power to the output stage = 11.3A x 13.4V = 153W
Power dissipated as heat, by the output transistors = 153W - 100W = 53W
If I reduce the RF output power to 30W, by reducing the drive:
RF output power = 32W
Average drain current = 7.2A
Drain voltage = 13.5V
Total electrical input power to the output stage = 7.2A x 13.5V = 97.2W
Power dissipated as heat, by the output transistors = 97.2W - 32W = 65.2W
If I reduce the RF output power to 15.3W, by reducing the drive:
RF output power = 15.3W
Average drain current = 5.1A
Drain voltage = 13.6V
Total electrical input power to the output stage = 5.1A x 13.6V = 69.4
Power dissipated as heat, by the output transistors = 69.4W – 15.1W = 54.1W
Stu
AB2EZ
Stu
AB2EZ
