6m & 8000DLE
Posted: Sun May 14, 2017 5:54 pm
by Simon
6m is alive with sporadic-E and lots of splatter :)
Running the 8000DLE here, 3 element beam pointing at the Balkans.
Re: 6m & 8000DLE
Posted: Sun May 14, 2017 6:07 pm
by G0MGM
Will have a listen on mine!
Rob
Re: 6m & 8000DLE
Posted: Sun May 14, 2017 6:24 pm
Hi Simon,
Where can we download the latest with transmit capability? I need to reinstall this on my new PC.
Re: 6m & 8000DLE
Posted: Mon May 15, 2017 7:37 am
by Simon
w-u-2-o wrote:Hi Simon,
Give me a day or two - I've just fixed a bug re: the 6m pre-amp and want to check the TX audio when using a USB microphone. I have to finish the current bit of coding as well. Once this is done I'll get the 10E onto the desk and start supporting the Protocol 2 firmware more as it's getting quite good.
Re: 6m & 8000DLE
Posted: Mon May 15, 2017 8:55 am
by G0MGM
Tnx for the heads up on 6m Simon. Managed to work some stations. Looking forward to your software being ready.
Still running Protocol 1 but was having issues with PS2 on 6m. It would run fine for a bit then it would reduce the output power so much that it would not work. I would then turn off PS2 and output would be restored until PS2 was turn on again and it would repeat.
Did a database reset but still happened. Not sure if it's a bug or not?
Rob
Re: 6m & 8000DLE
Posted: Mon May 15, 2017 9:23 am
by Simon
G0MGM wrote:Tnx for the heads up on 6m Simon. Managed to work some stations. Looking forward to your software being ready.
Rob
Hi Rob,
I don't use Thetis so can't really comment other than to say I haven't seen power issues myself using Protocol 2 but I've only has short sporadic-E QSO's on 6m. I haven't had any issues with longer 'old man' QSOs on 60m.
Re: 6m & 8000DLE
Posted: Mon May 15, 2017 9:26 am
Simon wrote: Scott,
Sounds good, Simon, thanks! :)
