I can duplicate this. It seems anywhere one is in a band segment labeled "Out of Band" or "Shortwave" the band buttons are gone from the display.
Re: Band buttons dissappear and appear again
Posted: Sun Jul 09, 2017 8:38 pm
by W1AEX
I can confirm that I saw this behavior in the 2.4.3 beta as well. I have not looked at 2.5.2 yet.
Posted: Mon Jul 10, 2017 2:16 am
by w5wc
The problem is most likely due to the particular skin that you are using. It may not have all of the necessary graphics. Try it with one of the skins that comes with Thetis or PowerSDR.
Doug W5WC
Posted: Mon Jul 10, 2017 2:36 am
by W1AEX
Hi Doug,
I went through all of them and the issue showed up with each skin in both 2.4.3 and 2.5.2. In the cases shown in the screenshots below I clicked on the "SWL" button and that made the band buttons disappear. If I cycled down to 1885 or any other frequency within a ham band the band buttons reappeared. It's an odd one!
Posted: Mon Jul 10, 2017 8:50 pm
by w5wc
Hi Rob,
The installer may not be adding all of the files. Please check to see if the following are included in your skins folder:
73, Doug W5WC
Posted: Mon Jul 10, 2017 9:55 pm
Can't speak for Rob, but I don't have those buttons in any of my skins, and I don't have any skins that show a July date that would be associated with a recent install of Thetis.
Posted: Tue Jul 11, 2017 2:42 am
by W1AEX
Hi Doug,
The radbandGEN series of buttons are present in the "OpenHPSDR-Gray", "IK3VIG Special", "Dark Metal", and the "High Visual" skins that are loaded by the installer so it looks like the installer is fine. However, they were not present in the ANAN skin that I made myself and copied over from my OpenHPSDR skins folder so I'll complete that set tomorrow.
I removed my incomplete ANAN skin from the THETIS Skins folder and then started up THETIS again but the issue still is present with the skins from the installer as can be seen in the little video. Not sure why that is happening.
Posted: Tue Jul 11, 2017 1:15 pm
by w5wc
The problem in Thetis is not the missing graphics. The SWL panel does not have a XY delta to keep it correctly placed on the console. If you resize the console to its minimal size you should see the SWL panel again. I will get this problem corrected soon.
Thanks, Doug! Does this also have the audio fixes we've identified so far?
Posted: Tue Jul 11, 2017 6:58 pm
by w5wc
It has the ones that you mentioned over the last couple of days where Warren and I have made the corrections. I was not able to duplicate your problems with the display freezing or the error from clicking on the band buttons.
73, Doug W5WC
Posted: Tue Jul 11, 2017 7:00 pm
by DL8LAQ
Thank you, Doug!
73, Norbert
Posted: Tue Jul 11, 2017 9:16 pm
by W1AEX
Thanks for tracking down the band button issue Doug. Works great now!
