NB effectiveness on static rain
Posted: Sat Aug 19, 2017 7:35 am
Being on a hill top does have its pros but the high antenna can also be prone to the so called static rain, which is not really caused by the rain drops discharging on the antenna’s elements, I must say my experiences are exactly as per Tom’s one (https://www.w8ji.com/pecipitation_static.htm).
When this happens, I can either switch to the lower antenna, on which the phenomenon is much less pronounced, or as I discovered this morning, simply by switching ON the noise blanker (NB), in the past I never really thought it could be beaten that way, but to my surprise, as can be appreciated on the linked clip, the noise totally disappeared!!!
Just to bear in mind in case it happens to you too guys
73, Clay
https://drive.google.com/file/d/0B493NR ... sp=sharing
73, Clay
