10MHz locked?
Posted: Sat Sep 30, 2017 7:57 pm
by W9IP
Dear friends,
I have installed the 10MHz daughter card in my Angelia. How can I tell whether it is locked to the 10MHz that I am supplying from a GPSDO?
W9IP
Re: 10MHz locked?
Posted: Sat Sep 30, 2017 9:11 pm
See page 2 of
this thread.
Re: 10MHz locked?
Posted: Sat Sep 30, 2017 10:07 pm
by W9IP
Thanks, Scott.
Follow-on question... what level (dBm) does Angelia's 10MHz input expect?
Thanks-
MRO
Re: 10MHz locked?
Posted: Sun Oct 01, 2017 12:55 am
I don't actually know. However, empirical evidence shows that it can be sine or square, single ended or differential, and pretty much any peak to peak voltage from 1 to 5 volts.
The schematic of the daughtercard is
here. I've never bothered to analyze it, myself.
BG7TBL and Bodnar GPSDOs are both proven to work. Anything with a 0 to 10dBm sine output into 50 Ohms, or a 3.3 or 5.5VDC single ended CMOS output, should work fine.
In other words, the input is robust and optimization of the signal type and level is not required for good performance.
Re: 10MHz locked?
Posted: Sun Oct 01, 2017 11:29 am
by W9IP
Fantastic, thanks again Scott.
W9IP
