CAT Control in PSDR mRX
Posted: Wed Nov 08, 2017 1:58 pm
by Prem
Hi Team,
Is the details on how to use CAT-2,3 &4 in PSDR mRX available here ?
If not anyone please guide me how to use it ?
Can we replace use of DDUtil with this option ?
I need to use CAT for : WSJTX, Mini deluxe and then HRD log
73s
Prem, A65BK
Re: CAT Control in PSDR mRX
Posted: Wed Nov 08, 2017 2:06 pm
There is absolutely nothing special required. They all work exactly the same as the main CAT port assignment. Simply attach as many programs simultaneously as you wish, up to a maximum of 4, of course, and they will all have full CAT control of the radio at the same time.
I use this feature to run WSJT-X, Fldigi and the DXLabs suite all simultaneously.
Unless you need some other special feature of DDUtil, it is not necessary.
Just hook stuff up and have fun!
Posted: Wed Nov 08, 2017 6:33 pm
by Prem
In this case, do we need to configure virtual port pairs in Com-0-com program ? or it is not required ?
I have Com-0-com running in my PC.
Is that the reason , when I tried second cat in PSDR, it was not working and showed some error !
73s
Prem
Posted: Wed Nov 08, 2017 6:54 pm
Yes, you need a separate serial port pair defined for each connection.
E.g. COM31 to COM32, COM33 to COM34, COM35 to COM36, etc.
Posted: Thu Nov 09, 2017 1:13 pm
by Prem
Thanks for advise. I could do it and work without using DDUtility. I use Virtual serial port pair also as required.
Settings I use are as below:
PSDR :
CAT : COM13 ; Baud rate 9600
CAT + : CAT2 : COM26 ; CAT3: COM25 ; CAT3:COM24. Enable all three with selection check box.
Com-0-Com :
Virtual Serial Port Pair set : COM14-COM24 ; COM15-COM25 ; COM16-COM26
WSJTX:
Radio : Kenwood TS2000
CAT control : Serial Port , COM15
PTT Method : CAT
Mini Delux:
Power SDR serial port : COM14
HRD Server Port :7809
HRDLog:
USed Mini Delux.
73s,
Prem
Posted: Thu Nov 09, 2017 6:29 pm
by SA3ATF
Good information!
I'm also going on with this so I thank and bug and return if I get stuck.
Tommy, sa3atf
