RCA PTT Out Reading
Posted: Fri Jan 12, 2018 8:24 pm
by Ei4gyb
Hi folks,
Belated happy New Year.
Wondering if anyone has measured the resistance of the RCA PTT out on the rear of the radio (200D) whilst in TX and then..... in RX ?
Any idea as to what readings can be expected? Should they vary from band to band?
Not sure but think it’s making the amp act a bit weird
Re: RCA PTT Out Reading
Posted: Fri Jan 12, 2018 10:28 pm
Here's the schematic for the PTT out circuit on the Orion board. It is similar on the other boards.
It's just a simple FET switch to ground with no internal pull-up. Therefore with PTT not asserted there will be near infinite resistance (an open circuit), and with PTT asserted it will be almost a short.
Posted: Sat Jan 13, 2018 12:29 am
by Ei4gyb
Thank you Scott.
That’s what I wanted to hear... Perfect !
Posted: Mon May 11, 2020 12:12 pm
by W6ACT
Hello everyone,
I have the anan 100 with amplifier keying issue. The RCA jack on the back of the rig has a dead short on it regardless if PTT is activated or not. As soon as I plug in my RCA cable the amp goes into transmit. I'm assuming there should be infinite resistance at RCA connector when PTT is not activated. The amp works ok with my other rig {FT-1000MP}. Diode D24 on the hermes board is the PTT switching diode could this be the problem, please help.
Alex
W6ACT
Posted: Mon May 11, 2020 12:18 pm
by w9mdb
Is this new behavior? Or is this from day one?
Sounds like it's time for some continuity checking....checking the diode in-circuit may work....especially if it shows a short.
https://www.fluke.com/en-us/learn/best- ... multimeter
de Mike W9MDB
Posted: Mon May 11, 2020 12:22 pm
by W6ACT
Hi Mike,
I did the continuity test with my ohm meter at the PTT jack and pin 1 on the 25 pin connector and both show the same result dead short regardless if PTT is activated or not.
Alex
W6ACT
Posted: Mon May 11, 2020 12:24 pm
by w9mdb
You need to measure that diode. I suspect you may see a dead short across that too.
I didn't look at the schematic but it sounds like short somewhere...solder blob...or some such thing.
Posted: Mon May 11, 2020 12:25 pm
by W6ACT
Yes it is new behavior I noticed that the amp was in transmit mode while Anan was in receive
Posted: Mon May 11, 2020 12:29 pm
by W6ACT
If anyone out here has the Anan 100 could they do a continuity test at the PTT jack while the radio is in receive and while in transmit and post the results for me.
Alex
Posted: Mon May 11, 2020 12:36 pm
by w9mdb
PTT Off -- infinite
PTT On (no power out) - 30 Ohms
Can't say I like the 30 Ohm measurement -- may explain why I sometimes my amp won't kick on.
I may have build my own take-it-to-ground circuit or figure out why it's not a dead short.
de Mike W9MDB
Posted: Mon May 11, 2020 12:43 pm
by W6ACT
Ok Mike, thats what I needed, 30 ohms is good enough to put your amp into transmit. You answered my question infinite resistance when PTT is not activated. That means I have a dead short somewhere on my PTT out circuit. Probably D24 the switching diode. Thank you very much for your help.
Alex W6ACT
Posted: Mon May 11, 2020 12:52 pm
by w9mdb
Actually appears borderline to me.
Periodically PTT will stop working and usually doing a tune on the tuner will correct it. Interestingly when I transmit about 6 watts the PTT reading shows 18 ohms.
I have an MFJ-998 doing the PTT control triggered by the ANAN 100.
Posted: Mon May 11, 2020 3:50 pm
by W6ACT
yup, I found D24 the BAT54 has a dead short on it. WOW how did this happen. SB-220 with soft key upgrade is not the problem. Cheap weak bat54 diode is the problem. This is not going to be a fun replacement.
Alex
W6ACT
