Fatal Error
Posted: Thu Mar 22, 2018 12:13 pm
by JG7PSJ
Hello all,
I got a 200d, so I installed the PowerSDR, but the PowerSDR does not start up with the following error message.
How should I solve it?
Using OS is Windows 7 Professional 64-bit SP1.
JG7PSJ Harry
Re: Fatal Error
Posted: Thu Mar 22, 2018 1:54 pm
Is this the very first time that PowerSDR has been installed on that PC?
Did you get PowerSDR from this repository:
https://github.com/TAPR/OpenHPSDR-PowerSDR/releases ?
Is your version of Windows 100% up to date per Windows Update?
Re: Fatal Error
Posted: Thu Mar 22, 2018 3:13 pm
by JG7PSJ
Yes, this is the 1st time installing of PowerSDR for this PC.
And I downloaded file from that URL.
Windows update is 100% of course.
Regards
JG7PSJ Harry
Re: Fatal Error
Posted: Thu Mar 22, 2018 6:01 pm
Unfortunately those were all the right answers. Therefore I'm running out of ideas.
Perhaps your anti-virus software is interfering somehow? Perhaps a video driver needs to be updated?
Re: Fatal Error
Posted: Sun Mar 25, 2018 4:08 pm
by w5rcq
I am seeing the same fatal error on my 200D with both version 8 and 9. My 200D runs older versions without problems. I am running Windows 10 Home with all updates and I downloaded the new version from GitHub. Any ideas?
Jerry W5RCQ
Re: Fatal Error
Posted: Mon Mar 26, 2018 2:26 am
by JG7PSJ
Solved. :D
My case was that the UAC level was too high.
JG7PSJ Harry
Re: Fatal Error
Posted: Mon Mar 26, 2018 12:48 pm
Thanks for posting that solution, Harry. With luck it will help others with similar problems.
Re: Fatal Error
Posted: Tue Mar 27, 2018 3:11 pm
by w5rcq
I am still seeing the fatal error listed by JG7PSJ when trying to upgrade to either V3.4.8 or v3.4.9. I am running Orion v 5.0 firmware on my 200D. I have tried all of the possible levels of UAC with no difference. Version v3.4.7 and below work just fine. I think this may be a Video card issue and I am running A Gigabyte Geforce GTX-1050ti with no other problems. This error happens as soon as the program starts its learning sequence. I am wondering if anyone other than JG7PSJ and I are seeing this Fatal error. I have removed all of the residual program information between trying various fixes and still no joy.
73 Jerry
Re: Fatal Error
Posted: Tue Mar 27, 2018 3:30 pm
Hi Jerry,
Just a random thought, because I really have no idea what is causing this: did you try running both the intaller, and PowerSDR as administrator? If not it might be worth a try.
Re: Fatal Error
Posted: Sun Apr 01, 2018 5:55 am
by w5rcq
Hi Scott, just an update on my problem installing v8 and v9. I tried several more things including running everything as administrator without success. I had about given up but I thought that my problem was connected to video somehow as the program install never even started before the fatal error was reported. I went to the Settings menu in Windows 10 and under size and layout you can adjust the size of text and apps and other items in steps of 100%, 125%, 150%, and 175%. I had set mine to 175% for a larger text size and Icons. I reset to 100% and everything now works. It is not a big deal but I believe it is a bug as all other version up through v7 worked just fine with the 175% setting. Thanks for your suggestions and the huge amount of time and effort you put into supporting us dummies. 73 Jerry W5RCQ
Re: Fatal Error
Posted: Sun Apr 01, 2018 10:48 am
Thanks, Jerry, and right back at ya'! ;) By sharing all of your hard work and the solution here you will be saving the next person who has this problem a lot of work.
Re: Fatal Error
Posted: Wed May 16, 2018 7:37 pm
by ON8GE
I have exactly the same problem, windows 7 pro, clean install, it accept 3.4.7 version without problem but if i upgrade it with 3.4.8 or 3.4.9, I receive this fatal error. I don't know why...
No idea ?
Pierre
Re: Fatal Error
Posted: Wed May 16, 2018 11:07 pm
Did you try the fix that worked for W5RCQ above?
Re: Fatal Error
Posted: Sun Nov 18, 2018 8:00 am
by bobutler651
Well it took me some while to find this thread but when I changed font size to 100% I was able to download 3.4.9. I had been using my computer for presentations and had changed font size for visibility. Next time
I used SDR on the system it crashed as other have found, thank goodness for forums!!!
Re: Fatal Error
Posted: Sun Nov 18, 2018 12:10 pm
