ANAN-7000DLE test report by Adam Farson, AB4OJ
Posted: Fri May 04, 2018 6:17 am
by va7oj
I am pleased to announce that my comprehensive ANAN-7000DLE Test Report is now also on my website.
http://www.ab4oj.com/sdr/apache/anan7000dle_notes.pdf
73, Adam VA7OJ/AB4OJ
Re: ANAN-7000DLE test report by Adam Farson, AB4OJ
Posted: Fri May 04, 2018 1:39 pm
by NC3Z
Adam, you made a note about the GPSDO degrading the RMDR. What GPSDO were you using?
Posted: Fri May 04, 2018 6:27 pm
by va7oj
I was using an HP Z3805A GPS receiver (which incorporates an HP 11801A OCXO). The Z3805A is my lab standard.
Posted: Fri May 04, 2018 6:59 pm
by NC3Z
So is this indicative off all external ref sources when used with the 7000? I am using a Trimble OCXO based GPSDO.
Posted: Fri May 04, 2018 10:28 pm
by va7oj
Hi Gary,
You can check by applying a test signal from a source with known low phase noise (e.g. a high-quality crystal oscillator) to the antenna port at about -10 dBm, and then connecting the GPSDO reference. If the noise pedestal on either side of the signal spike widens (on the spectrum scope), the external reference is degrading the receiver's RMDR.
