Acom 1010-Anan 7000DLE
Posted: Tue May 08, 2018 7:13 pm
by W4RAM
I just get my Acom 1010, this is the first time that I going to use an amplifier.
My question: is necessary with this amplifier test first the PTT linear amplifier circuit (KEY-IN)?, or Acom amplifiers come already with the proper voltage and amps required by radios like the Anan 7000DLE (24vdc, 1A?
If the amplifier already meet the requirements to be operate together with the Anan 7000DLE, will be good idea, for safety purpose, use an linear amplifier keying isolation adapter?
Thank you for your advice and recommendations.
Al
W4RAM
Re: Acom 1010-Anan 7000DLE
Posted: Tue May 08, 2018 7:53 pm
All you need is a shielded cable with RCA connectors on each end.
Posted: Tue May 08, 2018 8:26 pm
by Tony EI7BMB
Yep using Acom 600s here with just the cable
Posted: Wed May 09, 2018 7:12 am
by W4RAM
w-u-2-o wrote:All you need is a shielded cable with RCA connectors on each end.
Acknowledge. Thank you.
Al
W4RAM
by W4RAM
Tony EI7BMB wrote:Yep using Acom 600s here with just the cable
Thank you Tony, 73!
Al
W4RAM
