Orion MK II - Unstable frequency
Posted: Tue Jun 26, 2018 7:02 pm
Hi guys,
two week ago I did repair a 7000DLE with a toasted RX2 input (on the PA board) and a frequency stability fault.
The 10-MHz-REF-input on the OrionMKII did not work properly. Without external ref connected the TCXO was not supplied with 3.3 VDC, but 1.6 VDC instead. That was caused by a defective Q4 at the input amp (diff amp). I replaced Q3 and Q4 to fix this. After that the switching from internal to external ref worked fine again.
73, Norbert - holidays in JM57NH - CT7/DL8LAQ
