Omnirig and HPSDR setup ???
Posted: Fri Nov 09, 2018 2:20 pm
by OZ1CT-Ben
HI All
I have try to use Omnirig to controll my PSTrotator software, I have setup a virituel com 7 and made in HPSDR CAT 7 I turn on and name it Kenwood-2000.... then I turn on PSTrotator and it this I set it to use Omnirig in the setup (when I wil use Sattelite tracking) but it say that the transiver is connected.......
Any help here ????
Re: Omnirig and HPSDR setup ???
Posted: Fri Nov 09, 2018 2:59 pm
Ben--there's not enough information in your post to identify the problem. There could literally be twenty different possible answers.
Does Omnirig connect to PowerSDR?
Please post screen shots of your Omnirig setup screen, your PowerSDR CAT setup screen, and the setup screen of the virtual serial port software you are using. Then we can see what you did right, and what you did wrong.
P.S. moving this to the appropriate sub-forum...
Posted: Fri Nov 09, 2018 3:29 pm
by OZ1CT-Ben
HI Scott
Here is 3 photo of my setup ...and in the PSTrotator-sat-setup.png file you can see that it wil not connect to HPSDR via omnirig
73" OZ1CT Bent
Posted: Fri Nov 09, 2018 3:42 pm
Your VSPE setup is wrong. You need to use a "pair", not a "connector".
Set up a pair of ports. Assign one port of the pair to PowerSDR, the other to Omnirig.
Posted: Fri Nov 09, 2018 6:38 pm
by OZ1CT-Ben
HI Scott
I made the port as you write....but still not working...look at picture Omnirig-2error.PNG
Bent
Posted: Sat Nov 10, 2018 1:04 pm
When you get a "port is not available" error, that means that piece of software has not given up the port properly. You can restart the suspect software, or sometimes it is just simpler and better to reboot and start from scratch.
Posted: Sun Nov 11, 2018 11:21 am
by OZ1CT-Ben
HI Scott
Still no funktion...The program keep saying "Rig not responding"
and I have try difrent way to start/stop the software but still no luck !!!
I have downloade a software called "Omnirig-Client" and try so se what is going on,
but it get a error when I try to connect it " Status: Rig is not responding " so somthing is wrong...but where ???
73" Ben
Posted: Sun Nov 11, 2018 11:52 am
Rig not responding is better than port not found. Your virtual port setup looks good so I'm running out of ideas. I don't have Omnirig here to test. Can you set DTR and RTS to "none" in Omnirig? Also, you might as well increase your baud rate to the highest speed.
Posted: Sun Nov 11, 2018 8:20 pm
by OZ1CT-Ben
HI Scott
I asked Codrut who made the PSTrotator and he has it running whit Powersdr but it wil not run if you use HPSDR ????
he used a virituel com port software "Tibbo VSP Manager" I also try it out but but still no luck
so there must be a difference on Powersdr and HPSDR.....
Bent
Posted: Sun Nov 11, 2018 10:11 pm
Try setting Omnirig for a Kenwood TS2000 instead. The CAT commands are the same as for PowerSDR.
Posted: Mon Nov 12, 2018 10:46 am
by OZ1CT-Ben
HI Scott
IT WORKS NOW
I have downgrad HPSDR from 3.4.9 to 3.4.7 and then I start first PSTrotator and then HPSDR then it works
Posted: Mon Nov 12, 2018 12:12 pm
Did you change to the Kenwood setting?
You should not have to downgrade.
Posted: Mon Nov 12, 2018 8:10 pm
by OZ1CT-Ben
HI Scott
I try to use Kenwood-2k and PowerSDR in ver 3.4.9 but nothing worked... but I can try agn to install 3.4.9 to be 100% shure ??
73" Ben
Posted: Mon Nov 12, 2018 9:13 pm
by OZ1CT-Ben
HI Scott
I have now install HPSDR 3.4.9 and you have to as this to get it to work:
1. Start your vituell comport and staus in monitor has to be "Ready" ( I use
http://www.eterlogic.com/ )
2. then start PSTrotator whit Satellite tracking on, and config it to "PowerSDR" and Com:7 9600 Baud
3. then start HPSDR whit CAT interface as PowerSDR at Com:8 9600 Baud
then you wil get it to work
if you stop the tracking and wanted to start agn....you have to do step 1 to 3.....
73" Ben
Posted: Mon Nov 12, 2018 10:38 pm
Once you start VSPE you should never have to restart it.
So it would appear that Omnirig must be started first (bad software design!)
Good to know, thanks!
