ADC Overload! with Thetis v2.6.6
Posted: Sun Apr 28, 2019 12:03 am
				Hi Phil, Warren, Scott, et all,
I'm getting a flashing, cycling: "ADC1,2,3 Overload!" message after turning ON Thetis, by pressing its Power button.
I also get an annoying, uncontrollable TX/RX relay clicking noise with the following message:
"High SWR condition detected. Please check your antenna connection."
Of course, the antenna system was fine. I needed to press the MOX button several times to be able to STOP the clicking, put the radio in TX mode, then press MOX again, to get the radio back to normal receive mode.
Is this new version of Thetis incompatible with Hermes 10E/100B 14-bit ADC perhaps?
I'm using Thetis v2.6.6 (4/21/19) with my ANAN-100B 14-bit HermesII running P2 firmware v10.2 with a clean database.
I did not experience this problem with Thetis v2.6.0 (4/10/18) using the above same firmware.
Please fix this issue with new Thetis, firmware release soon!
Thanks in advance.
Manny K0MO
Thanks in advance.
Manny K0MO
