RX1 or RX2 noise floor goes full scale on Ver 1.9
Posted: Thu May 02, 2019 12:36 am
by NJ2US
This is happening more frequently, probably still a timing issue. 5 times in 3 weeks, in Thetis ver 2.6.6 and 2.6.7, P2 ver 1.9, either the RX 1 or RX 2 panadapter noise floor goes full scale. You hear floor noise, but its very evident that reception has stopped. It seems to occur as the transceiver transitions from TX to RX. 4 times on RX 2, 1 time on RX 1, captured here.
I'm guessing its a firmware issue, I don't know for sure.
Jeff
NJ2US
Re: RX1 or RX2 noise floor goes full scale on Ver 1.9
Posted: Thu May 02, 2019 1:32 am
by NC3Z
I am getting some real weirdness when I use S-ATT vs ATT on RX2. As I roll through the S-ATT from 0 to -31 the RX2 spectrum noise floor varies by 30 or more dB. But if I PTT the noise floor will recover to where it should be, until I adjust the S-ATT again.
If I use ATT and adjust I do not have this issue.
Posted: Sat May 04, 2019 8:15 pm
by n1gp
Hi Guys,
Could you try this new build, so far working well for me...
https://www.dropbox.com/s/ndahfr5zgh1l2 ... 1.rbf?dl=0
Tnx
-Rick / N1GP
Posted: Sat May 04, 2019 8:37 pm
by NJ2US
Thanks Rick, flashing now, I will report back.
Had the Full Scale floor jump occur twice this morning.
Jeff
NJ2US
Posted: Sun May 05, 2019 12:38 am
by NC3Z
Rick is this supposed to address the ATT issue I noted? If it is then it did not fix it.
Posted: Sun May 05, 2019 12:55 am
by NC3Z
Not sure if this shows you enough of what I am seeing:
https://www.youtube.com/watch?v=tu1ezjAxhFU
Posted: Sun May 05, 2019 2:22 am
Gary,
Other than your RX2 issue, which may be Thetis related, how is 2.0 working for you?
Posted: Sun May 05, 2019 11:53 am
by NC3Z
No RX2 max rise of the spectrum so far, whether it is related to the spectrum level changing with PTT when in the S-ATT mode is unknown (and unknown really if it is P2 or Thetis.
It may very well be 2 separate issues we are seeing that causes the spectrum level to rise and fall drastically.
Posted: Sun May 05, 2019 2:45 pm
by NJ2US
Pre release 2.0 stable after 6 hours of operation so far, no panadapter noise floor rise. RX2 Step Attenuator continues to exhibit its anomaly as noted by Gary NC3Z.
Jeff NJ2US
Posted: Sun May 05, 2019 2:56 pm
by NJ2US
I don't have a 100D, 2.0 working very well at this point.
Jeff NJ2US
Thetis 2.6.7
7000DLE
Windows 10 Pro i7 3.6 Ghz 16gb RAM
Posted: Sun May 05, 2019 3:56 pm
by NC3Z
I am running a 7000DLE. Good question on what worked well last as we have had a few Thetis and firmware updates over the last couple of weeks it is hard to say.
Posted: Sun May 05, 2019 3:57 pm
by NC3Z
Jeff, do you still see the S-ATT issue?
Posted: Sun May 05, 2019 5:18 pm
by NJ2US
The S-ATT issue persists on RX2, in fact the 10-20-30 db steps don't seem to behave as expected either.
Also, 5 hours of continuous net control operations on 40 meters this morning, with no spectrum jumps on FW 2.0 (Orion MKII)
Jeff
NJ2US
