Anan 7000 DLE MKII & WSTJ-X
Posted: Fri Nov 08, 2019 7:08 pm
by qst
Hi to all,
I have a problem with my Anan configuration with WSTJ-X program. Please help.
Slawomir
Re: Anan 7000 DLE MKII & WSTJ-X
Posted: Fri Nov 08, 2019 7:17 pm
by Tony EI7BMB
Hard to help without knowing what the problem is , can you give some more information ?
Posted: Fri Nov 08, 2019 7:36 pm
Moving this to the digital mode subforum where it belongs.
Give us more info and we'll try to help.
Posted: Fri Nov 08, 2019 7:38 pm
by NC3Z
Reboot
Posted: Sat Nov 09, 2019 10:57 am
by qst
Hi,I installed 4 Virtual Audio Cable-Muzychenko. In the Power SDR - audio-VAC setup I choose the MME driver. The input is only Line 3 and line 4 (VAC). The output is VAC 1, VAC 3 and VAC 4 (VAC). This is probably not correct. Which ports should I choose in input and ouput VAC1 audio setup in HPSDR?
Slawomir
Posted: Sun Nov 10, 2019 3:47 pm
Slawomir,
Please post some screen shots of your WSJT-X audio setup, PowerSDR VAC setup, and Muzy VAC setup screens. You can use the "Attachments" tab below the main editing window here to do that. Then we'll have a better idea of what's going on.
Posted: Mon Nov 11, 2019 9:41 am
by qst
thank you for your answer. I have partially solved the problem. Audio drivers after the WIn 10 update did not work properly. I can already see 4 virtual cables in the HPSDR setup. But only you can see them when the MME driver is enabled. When I turn on the Windows WDM-KS driver, there is no VAC in the input and output window. Maybe this is a problem of the Muse VAC program. WDM-KS is also in the older version. I send screenshots.
73's
Slawomir
Posted: Mon Nov 11, 2019 12:13 pm
Windows updates are known to damage noon-Windows sound drivers.
Uninstall VAC. Reboot. Reinstall VAC. Reboot. Then try setting it all up again.
Posted: Mon Nov 11, 2019 3:39 pm
by qst
Hi Scott,problem solved. By default, the new version of VAC Capture port and Render port is turned on "auto" I changed to Wave PCi and now everything works ok. In the Window WDM-KS driver in the input and output tab virtual cables are visible. Everything works ok.
Thank you for the advice. Best wishes.
Slawomir
Posted: Mon Nov 11, 2019 6:58 pm
by qst
after VAC configuration I turned on WSJT-X. The Wide Graph shows working stations, the reception level in the Ban Acitivity window is about 70% and there are no working stations. I have enabled CQ and correspondence can see my sign. A few people called me but I didn't see them in the window. I don't know what I did wrong in HPSDR or WSJT-X configuration. What can I check and change to correctly receive stations and work on FT8?
Slawomir
Posted: Mon Nov 11, 2019 7:03 pm
by NC3Z
Are you using anything to ensure your PC clock is accurate?
Posted: Mon Nov 11, 2019 7:04 pm
by NC3Z
Your input level to WSJT is also very, very high.
Posted: Tue Nov 12, 2019 5:47 am
by qst
Hi, I solved the problem. I had to change Driver WDM-KS to MME and everything started to work properly. I don't know why WDM-KS doesn't work. Various configurations are shown on Youtube. Only MME works for me and I will leave it that way.
Greetings to all.
Slawomir
