Audio problem on Thetis
Posted: Thu Nov 14, 2019 8:53 pm
by m5bjc
Hi All
I have a problem with Thetis start up, when loaded up and I press ON there is no audio and the pan adapter is very narrow, but after about 15 seconds it all works fine. I think this was caused by a Windows 10 update about 3 weeks ago.
I am running a Anan 8000DLE which is great, and have had for about 2 years.
Has anybody else had this problem, I am running the latest Thetis version now, but still has this problem.
Thanks All
Brian M5BJC
Re: Audio problem on Thetis
Posted: Thu Nov 14, 2019 9:41 pm
Are you using VAC for audio, or are you listening through the 8000 headphone/speaker connections?
Posted: Fri Nov 15, 2019 8:18 am
by m5bjc
Hi There
I am using speaker socket.
Brian M5BJC
Posted: Fri Nov 15, 2019 11:50 am
Hate to give this time-worn answer, but have you tried saving your database (so that you can go back to it) and then seeing if this happens with a reset (fresh) database?
Posted: Sat Nov 16, 2019 8:23 am
by m5bjc
No if I save the Database and reset it, It still does the same thing, no audio and narrow pan adapter for about 15 seconds and then audio comes
on and full width pan adapter and all works fine.
Posted: Sat Nov 16, 2019 12:54 pm
What version of firmware is in the 8000?
Posted: Sat Nov 16, 2019 8:50 pm
by m5bjc
I am running Protocol 2 V1.9 and latest Thetis
Posted: Sat Nov 16, 2019 9:33 pm
m5bjc wrote:I am running Protocol 2 V1.9 and latest Thetis
Have you seen this topic?
Try the three versions posted there. Use the one that works the best.
Posted: Sun Nov 17, 2019 8:13 am
by m5bjc
OK thank you, I will try when I can, I have to go to Italy today due to work so will have to wait a week.
Just find it funny that it has been fine for around 2 years, and I am sure it happened after a Windows 10 update.
Thanks for your help.
Posted: Mon Nov 25, 2019 7:35 pm
by m5bjc
The problem was solved with a bios update on my Dell computer, why this should happen I am not sure, but must have been from the
windows 10 update which I thought had caused the problem.
Regards
Brian M5BJC
