CAT UDP
Posted: Sat Nov 30, 2019 10:58 pm
So under the CAT tab in settings there is a spot to put a UDP port for N1MM. Is there a way for Thetis to send out UDP Freq info in the N1MM require format?
I currently use the CAT port to DXLabs Commander in order to send UDP freq info to my HF Auto, but if I could eliminate 1 step (Commander).....
