Audio drop-outs when using DAW or VST Host
Posted: Sun Dec 22, 2019 12:28 am
I know that some of you are using Digital Audio Workstations or VST Hosts for audio processing which prompted these questions:
1). I assume that you have a "dedicated" PC to run both the SDR and DAW or VST Host with plug-ins, correct?
2). If the answer to the above is in the affirmative, have you noticed audio drop-outs or other such "glitches" in your transmissions that would be traceable to using DAW or VST Host for your audio processing?
3). There are some excellent tutorials on how to build a PC that is truly dedicated to audio processing when employing a DAW or VST Host which have done away with a lot of the "bloatware" PCs come with that are deleterious on DAW and VST Host processing of audio. Depending on the extent to which one uses DAW (and especially the number and type of plug-ins) for audio processing a truly dedicated PC to audio may not be necessary, right?
4). Doesn't ANAN SDR in essence also process audio in the digital domain and you may also experience audio drop-outs, correct? The hardware in ANAN SDR with its FPGAs may make audio processing by the SDR rig inherently more efficient as well and audio drop-outs may not really be a concern at all, correct? I must admit that I don't know at all how audio is processed in ANAN and the FPGA may have absolutely nothing to do with that aspect at all.
5). Am I correct in thinking that even if one has a workstation grade machine with - say - an i9 CPU in it one might experience audio drop-outs as there are many functions such as automatic software updates and a myriad notifications that are going on in the "background" that potentially cause audio drop-outs, correct? When I say audio "drop-outs," I am mainly alluding to those that you may experience when using DAW or VST Host for audio processing.
6). Are there functions in a very hight performance PC when running just SDR that you have had to disable completely to not have any sort of audio drop-outs or other types of "glitches" when NOT using DAW or VST Host for audio processing and using what ANAN enables by itself?
It would be great to hear your thoughts and comments on the above questions.
Best,
- NI2M
Best,
- NI2M
