JTDX 64 bit audio solution
Posted: Wed Jan 29, 2020 1:59 pm
by Tony EI7BMB
Hi Guys, when I changed from 32 bit to 64 bit JTDX I noticed the output audio level was way down. Found the solution on the JTDX mailing list which is to install the 64bit version in a new folder "C:\JTDX64" for example
Hope this helps
Re: JTDX 64 bit audio solution
Posted: Wed Jan 29, 2020 3:10 pm
by w9mdb
That would indicate there were left-over files from the 32-bit installation getting in the way. All you should've needed to do was clean the old directory. And an uninstall should have removed any such binaries. Did you uninstall the 32-bit first?
de Mike W9MDB
Posted: Wed Jan 29, 2020 4:21 pm
by Tony EI7BMB
No Mike as did not want to lose all the settings . New directory is an easier solution for me anyway
Posted: Wed Jan 29, 2020 4:31 pm
by w9mdb
Settings aren't maintained in the installation folder.
You can uninstall and reinstall and it remembers everything.
You have to manually remove settings.
They are in %LOCALAPPDATA% under the program name.
Posted: Wed Jan 29, 2020 7:46 pm
by Tony EI7BMB
good to know Mike Thanks
