I'm trying to ID lines on waterfall
Posted: Sun Feb 09, 2020 9:18 pm
Hopefully I put this in the correct topic. Today I was going through the bands. They are more quite then normal. When I got to 20 meters found this. Hundreds of lines on the waterfall. It's not on any other band. I've tried all sorts of things to change or eliminate it. I don't seem to hear anything different. I've been through the house unplugging everything. Practically all the Wall warts have been unplugged. I live in an area pretty far out in the country. I'm running a 535 ft (approx) 160 meter loop. Here is a what it looks like. I've had lines on the waterfall before, but a few in number. I know the digital signals on the left of the frequency band. Can anyone help me identify these if you have ever seen anything similar?
I'm sure it's some kind of noise. I would just like to know what kind if that's possible. I've connected a lot of equipment and have a lot of software running. I't all running well. I need to go through all my wiring and make sure it's grounded or shielded. It's a rats nest now. That may be the answer to my question. The lines span a frequency range from about 10 mhz to 18 mhz. Is there more information I could give that would help identify? Thank you
