Thetis Proper upgrade procedure
Posted: Tue Mar 10, 2020 9:58 pm
by kg2is
Can someone point me to proper Thetis upgrade procedure from example ver 2.6.7 to 2.6.9 or 2.7.0 please?
Problem I have is every time I upgrade, still same version shows in upper left Thetis corner but I believe newer
version has been successfully updated.
I was trying to ask around local folks but many different opinions around.
Mike KG2IS
Re: Thetis Proper upgrade procedure
Posted: Tue Mar 10, 2020 10:06 pm
by NC3Z
This is covered in another thread, but first go into Windows uninstall programs and see how many Thetis you have. If there are more than 1 you need to uninstall.
But the other thing when jumping several versions, especially when the database items get changed, do a database reset, and preferably re-enter your settings by hand. I keep screen shots of all my main setup screens and can quickly rebuild my database manually.
Posted: Wed Mar 11, 2020 1:08 am
To amplify Gary's post, this is what I recommend:
Step 1: if you are upgrading from before 2.6.9, screen shot your settings, uninstall everything, reinstall 2.6.9 from the
official release, redo your settings manually. Otherwise, if you've already got 2.6.9 skip to Step 2.
Step 2: if you want to experiment with 2.7.0, make a backup of your settings by exporting your database file just in case you need to go back to Step 1. Then download Richie's latest dropbox link from the
official 2.7.0 topic and copy/paste those files over the top of what you've got in C:\Program Files (x86)\OpenHPSDR\Thetis
Advanced methodology:
Make a backup copy of C:\Program Files (x86)\OpenHPSDR\Thetis
Make a backup copy of C:\Users\<your username goes here>\AppData\Roaming\OpenHPSDR\Thetis
Make your changes. See if you like them. If you don't, delete the two directories named above and rename (or copy) the backup directories back to their original names as given above.
You can keep as many versions on your hard drive like this as you like.
Posted: Sun Mar 22, 2020 1:33 pm
by kg2is
Gentleman's
This work perfect.
Thank you
