Connect transverter to 10E
LA0GE
Post by LA0GE »
Hi
I need help connecting my Anan 10E and my SSB LT2S transverter. I have connected the transverter to the
rx and tx sma on the 10E. Receive works, but I am not sure if I can transmit with it or if any checkbox needs to
be checked/unchecked before I tx with it. Would like to not kill the 10E :) Reason for using the rx/tx sma connection is that I asked W6PQL
and he told me that he used these connectors.
What is the XVTR connector for if the rx/tx connectors do the same?
G0MXH
Re: Connect transverter to 10E
Post by G0MXH »
Hi
Sorry I am not familiar with the SSB transverter but it would depend on your transverter connections, some split tx and rx and some have a common input.
So on mine I just used the XVTR sma connector to connect to the common (Rx/Tx) port on my transverter.
I didn't use the BNC XVTR IN connector as I am guessing that is for splitting Rx & TX.
The two important things are to make sure you Disable PA in XVTR setup, I also left XVTR RF TX unticked and the second is don't forget the PTT connection.
For Split connections have a look at the Khune TR144 Pro manual Anan setup, it might give you some ideas.
LA0GE
Post by LA0GE »
Hi.
Thank you very much. I will have a look at Kuhne.
Bent
Return to “Transverters”
