Need schematic for ANAN-10 (hermes) TCXO daughterboard
Posted: Sat May 09, 2020 12:50 pm
by BrianLloyd
My ANAN-10 stopped using the internal 10MHz TCXO reference, which ends up pulling the ADC clock off by about 100ppm. It works OK using an external reference. I need the schematic (and hopefully board layout) in order to troubleshoot.
I initially suspected how the 10MHz TCXO was soldered to the board and ended up reflowing those connections but that didn't solve the problem. I am able to confirm that the 10MHz from the on-board TCXO is getting onto the board but then it disappears.
I sent email to Apache Labs support mailbox but that bounced with "mailbox full". I remember when someone posted the design for this but it was about 10 years ago and doesn't seem to be in the archives.
Thank you for your help.
Re: Need schematic for ANAN-10 (hermes) TCXO daughterboard
Posted: Sat May 09, 2020 2:00 pm
It would appear you did not look at the schematics section of this forum... ;)
https://apache-labs.com/community/viewforum.php?f=35
Posted: Sat May 09, 2020 5:59 pm
by BrianLloyd
Thank you. Before I asked I searched the site. I evidently used the wrong keywords. After much additional effort I did find it referenced in another message. Still haven't found the schematics section. Where might one look for that?
Thank you.
Posted: Sat May 09, 2020 6:34 pm
Brian,
Did you not follow the link I put in my first post above? If not, why not?
Posted: Sun May 10, 2020 4:58 am
by DH1KLM
Posted: Sun May 10, 2020 10:19 am
by BrianLloyd
Thank you both for the links. Problem located. Bad diode. Diodes on order from Mouser.
