Routing audio output to a virtual audio cable?
Posted: Tue May 12, 2020 7:02 pm
I'm just beginning to get my feet wet with a new-to-me ANAN 100D that I'm using with PowerSDR mRX PRS v3.4.9 under Windows 10.
I've gotten as far as hearing audio via headphones plugged into the front panel. Now I'd like to route audio output to a virtual audio cable so that I can send it to decoder software such as FLdigi.
I see in PowerSDR mRX there's a menu Setup > Audio that has tabs marked VAC 1 and VAC 2, but this consists of fairly detailed settings. Is there a basic setting somewhere that I can use to select what audio device defined within the Windows sound system I want to send the output to? Thanks in advance.
