Waterfall level setting
Posted: Mon May 18, 2020 3:05 am
by vk6cpu
I'm currently running Thetis v2.7.0 (a3).
I used to be able to set the level of the waterfall display by clicking and dragging on the left hand side of the spectrum display.
Has this facility been removed in the latest versions OR have I turned off the option somewhere ?
I've been through all the tabs on setup and so far drawn a blank.
Re: Waterfall level setting
Posted: Mon May 18, 2020 12:44 pm
by PD3LK
Hi, when i uncheck this box then it doesn't work for me either so i think this is what you are looking for.
73, PD3LK
Posted: Mon May 18, 2020 3:09 pm
by rbduck
All right you have my attention. Where exactly on the left side of the spectrum display are you clicking and dragging? I was unaware the waterfall display level was adjustable this way. Thank you.
Posted: Mon May 18, 2020 3:28 pm
by PD3LK
When you drag the spectrum up or down then the waterfall gain can follow this way.
Posted: Mon May 18, 2020 3:34 pm
by rbduck
Perfect! That works. Thanks!
Posted: Tue May 19, 2020 1:58 am
by vk6cpu
Thanks Leon!
That works for me too!
Problem of my own creation solved! :D
