Pure signal fixed attenuator
Posted: Sun Jun 07, 2020 6:10 pm
by W9BHI
I am using the xtronic coupler and a 20 db fixed attenuator on my 200D .24 radio.
If I should upgrade to a 7000DLE, would the fixed attenuator the same?
Don W9BHI
Re: Pure signal fixed attenuator
Posted: Mon Jun 08, 2020 1:24 am
Don,
This topic is what you need to read:
https://apache-labs.com/community/viewt ... =20&t=2384
However, the TLDR version is, assuming you are only running the 100W, then that's 50dBm out, less the 44dB coupling factor, so +6dBm peak out of the coupler. That's well below the safety limit of +13dBm, so no attenuator is required at all for either radio. +6dBm is also close to the optimum value for maximum signal-to-internal crosstalk level. Dump the attenuator for either radio.
